HKS Hi Power Post Install Pics...Lopsided?
Old Mar 21, 2008 | 12:44 PM
msukach's Avatar
msukach
Question HKS Hi Power Post Install Pics...Lopsided?
The HKS went on an 08 350z NISMO edition...however, it seems the left muffler sits higher than the right.
Post Install Shots
Thought about just bending the left hanger a little...bad idea?
Old Mar 21, 2008 | 02:59 PM
stylett9's Avatar
stylett9
i can't see your pictures because i'm at work but it's a pretty common problem for one side to be slightly off from the other side. When i had an invidia G200, my left side drooped slighly lower then the right. The mechanic bent the hanger a little bit and problem solved. But again, i cant see your pics so i don't know how drastic your differances are.
Old Mar 21, 2008 | 03:02 PM
DBTRACK's Avatar
DBTRACK
bend the hanger.... problem solved
Old Mar 21, 2008 | 03:08 PM
SuperBlack350z's Avatar
SuperBlack350z
+1 easy fix.
Old Mar 21, 2008 | 04:19 PM
msukach's Avatar
msukach
To All-
Thanks for the quick feedback.
Problem solved indeed.
Old Mar 22, 2008 | 03:48 PM
kirradude1025's Avatar
kirradude1025
Mine is fine...post a pic of yours
Old Mar 22, 2008 | 04:49 PM
msukach's Avatar
msukach
You'll see from the pics, the left hangs a bit higher-and is touching the bumper. It's going back on the lift tomorrow so I can bend the hanger just a little.
http://cid-e97123214e8a140e.skydrive...Post%20Install
If this link doesn't work for you, try my initial post--"HKS Post Install"
Old Mar 23, 2008 | 05:05 AM
msukach's Avatar
msukach
Before I bend the metal hanger on the car, does anyone know if there's a slightly longer rubber bushing that I might use instead?
Old Mar 23, 2008 | 06:49 AM
kirradude1025
When I went back to check, the pipes nor anything else was touching the bumper and I could get a finger between the tip and bumper in all places.
Old Mar 23, 2008 | 08:20 AM
06dieselZ's Avatar
06dieselZ
its normal dude mine does it too
Old Mar 23, 2008 | 04:58 PM
Sensi09's Avatar
Sensi09
Works Concepts
Could you post more pics please. Preferably shots of the entire rear section.
I haven't seen to many NISMOs with aftermarket exhausts. I'm thinking about the HKS too.
Old Mar 23, 2008 | 05:21 PM
msukach's Avatar
msukach
Sure...when I get home from work tomorrow, I'll take a few angles. I'm also going to post a video--better than this one:
HKS Hi Power True Dual system
This one is not very good--too much wind and not enough recorded.
Old Mar 24, 2008 | 11:17 AM
Rekinyze's Avatar
Rekinyze
What is that extra canister on each side for? Is that a resonator?
Old Mar 24, 2008 | 01:08 PM
msukach's Avatar
msukach
I'm not entirely sure what that canister is or does--resonator, I would guess.
BTW...went to bend the hanger today but have determined that I can't...lowering it enough for the canister to clear the bumper would be too low...and there's no way that I can see to adust it otherwise.
About all I can think of is to make a small half-moon incision (about 1/2") so that the cansister isn't touching.
I'll get back under the car when the TPs go in...
Old Mar 24, 2008 | 01:37 PM
06MagneticZ's Avatar
06MagneticZ
How do you guys keep the exhaust from touching the big "M" or "W" shapped cross member? My HKS is sitting on that and it rattles.
Old Mar 24, 2008 | 04:56 PM
toca07's Avatar
toca07
hks loos nice with the rear bumber of the nismo
Old Mar 29, 2008 | 07:22 PM
msukach's Avatar
msukach
So far, no burn or melting...not even any vibration...when the TPs go in...maybe I won't have to bother w/the cutting the rear bumper.
350Z_Al
Oct 29, 2020 07:44 PM
codek
Sep 28, 2015 03:03 AM
