what tool do i need to install (HFC,exhaut and spacer)
Old May 14, 2008 | 01:36 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by Hydrazine
That picture shows the metallic cat.
The metallic is the stainless steel metal foil used as the substrate and support.
The white stuff on the foil is the actual catalyist material. Its a mixture of ceramic and nano size particles of platinum, palladium, rhodium and other precious metals.
You can't see the precious metal particles because they are so small but the white stuff is the ceramic portion of what cleans your exhaust gasses.
All that stuff starts out as a slurry that is sprayed onto the substrate, dried and fired in a kiln.
sometimes I doubt whether the aftermarket cats actually include all the precious metals. rhodium in particular is probably the most expensive metal in the world right now . one of these days i should take a sample of the cats and throw it on the energy dispersive x-ray machine (uses x-rays to do chemical identification) and see what they really put on there.
I've also developed a really awesome catalyst that can be made cheap, works for a lot of stuff and doesn't use any precious metals
Old May 15, 2008 | 04:17 PM
LMG_35C's Avatar
LMG_35C
So when you're putting the O2 sensors back on the HFC's do you use anything on the threads like anti-sieze compound?
Old May 15, 2008 | 04:30 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
You certainly can, but I would be a little cautious with it and not use too much.
The sensors are really sensitive and can easily be fouled by just about any contaminant other than exhaust fumes.
Old May 15, 2008 | 04:37 PM
Hydrazine's Avatar
Hydrazine
It sure is.
BTW are you getting your catalyst patented? If it can substitute the precious metals, it'll make you a millionaire (billionaire) overnight!
GOOD LUCK WITH IT!
Old May 15, 2008 | 11:50 PM
Darkness75's Avatar
Darkness75
It sure is.
GOOD LUCK WITH IT!
lol
about the O2 sensour , can i use the old ones or should i get new ?
Old May 16, 2008 | 04:12 AM
Hydrazine's Avatar
Hydrazine
Keep the old ones unless you can somehow verify their condition.
Old May 16, 2008 | 01:54 PM
Darkness75's Avatar
Darkness75
update
i jacked my Z ,from what i see its hard to remove the cats but it doable installing the HFC alon thats what i`m wondering HOW ?(HOLDING AND BOLTING ON ,WITH LOW SPACE OF JACK STANDS)
i socked the bolts with WD40 waiting to start tomorrow .
Old May 16, 2008 | 02:21 PM
soccertoad's Avatar
soccertoad
Let us know how it goes. I'm gettong ready to install my Fast Intentions HFC's - my 3 yr. Nissan warranty just ran out.
Old May 17, 2008 | 12:14 PM
Darkness75's Avatar
Darkness75
socking the bolts worked fine ,bolts are off no problems (reaching them is PITA)
go for it dude its fun to do it your self , get the tools and you`ll do fine
Old May 18, 2008 | 03:23 PM
Darkness75's Avatar
Darkness75
check out my thread :
https://my350z.com/forum/showthread....47#post5755647
should i install the HFC first or start with the exhaust ??
Old May 18, 2008 | 03:40 PM
Hydrazine's Avatar
Hydrazine
Install everything losely first.
Then start tightening everything down tightly starting from the cats back.
Old May 18, 2008 | 11:10 PM
Darkness75's Avatar
Darkness75
thank you man ,,,always a great idea`s n help ,keep them coming
Old May 21, 2008 | 05:11 AM
Darkness75's Avatar
Darkness75
update : (sorry the pics are sooo bad by mobile )
i installed the APS 2.5" ,no problems except in removing and installing the muffler ,if you have a Friend to help you it would be faster and easier ,if not do as i did :
<a href="http://s273.photobucket.com/albums/jj206/Darkness1975/?action=view&current=installingtheAPS.jpg" target="_blank"><img src="http://i273.photobucket.com/albums/jj206/Darkness1975/installingtheAPS.jpg" border="0" alt="Photobucket"></a>
<a href="http://s273.photobucket.com/albums/jj206/Darkness1975/?action=view&current=installingtheAPS2.jpg" target="_blank"><img src="http://i273.photobucket.com/albums/jj206/Darkness1975/installingtheAPS2.jpg" border="0" alt="Photobucket"></a>
i jacked them
so i just need to do some adjustment and a sound clip will be ready tomorrow yeah ,,,(and a dayno if i got the time)
<a href="http://s273.photobucket.com/albums/jj206/Darkness1975/?action=view&current=APS25-muffler-installed.jpg" target="_blank"><img src="http://i273.photobucket.com/albums/jj206/Darkness1975/APS25-muffler-installed.jpg" border="0" alt="Photobucket"></a>
<a href="http://s273.photobucket.com/albums/jj206/Darkness1975/?action=view&current=APS25-muffler-installed2.jpg" target="_blank"><img src="http://i273.photobucket.com/albums/jj206/Darkness1975/APS25-muffler-installed2.jpg" border="0" alt="Photobucket"></a>
Old May 22, 2008 | 12:56 AM
Darkness75's Avatar
Darkness75
Default installed heeey ,,,but !!
Help guys :
i installed the exhaust the sound is so dame beautiful ,,,deep no rasp in WOT and quit in IDLE
only one thing i need help with >> the tips are not in-line :
<a href="http://s273.photobucket.com/albums/jj206/Darkness1975/?action=view&current=tipesnotcorrect.jpg" target="_blank"><img src="http://i273.photobucket.com/albums/jj206/Darkness1975/tipesnotcorrect.jpg" border="0" alt="Photobucket"></a>
this is the right tip :
<a href="http://s273.photobucket.com/albums/jj206/Darkness1975/?action=view&current=lefttip.jpg" target="_blank"><img src="http://i273.photobucket.com/albums/jj206/Darkness1975/lefttip.jpg" border="0" alt="Photobucket"></a>
left tip :
<a href="http://s273.photobucket.com/albums/jj206/Darkness1975/?action=view&current=righttip.jpg" target="_blank"><img src="http://i273.photobucket.com/albums/jj206/Darkness1975/righttip.jpg" border="0" alt="Photobucket"></a>
any idea`s other than removing the muff and adjusting the hangers
sound clip tonight ,,dayno tomorrow
Old May 22, 2008 | 03:59 AM
Hydrazine's Avatar
Hydrazine
I can see the muffler is also slanted.
Remove and adjust may be the only way to fix it.
Old May 24, 2008 | 12:09 AM
Darkness75's Avatar
Darkness75
video clip
https://my350z.com/forum/showthread....50#post5788250
thanx to all your help :P
EnjukuRacing
Sep 30, 2015 06:55 AM
