Nismo Y Pipe Flex Joint
Old May 20, 2008 | 10:08 AM
BabyZiLLa's Avatar
BabyZiLLa
Default Nismo Y Pipe Flex Joint
Got my Nismo exhaust with Berk test pipes installed a few days ago.
Sounded awesome and all was good. Just yesterday though I started getting a slight noise in parts of the RPM band on accelration and the noise is amplified 10 fold when i let off the gas with back pressure.
So i took a look. It is the Nismo Y Pipe flex joints. There vibrating and making all sorts of racket on back pressure.
Their not touching anything though, just doing it themself.
Anyone heard of this before?
I was expecting an exhaust leak when i went under the car. Not this.
Old May 20, 2008 | 10:38 AM
SuperBlack350z's Avatar
SuperBlack350z
your flex pipes are leaking. Nismo y pipes have this problem if mated with test pipes. Do a search .
Old May 20, 2008 | 10:41 AM
BabyZiLLa's Avatar
BabyZiLLa
I started searching and found exactly what you just said.
Wow. 2 days.. Good job Nismo.
Since I have solid motor mounts I guess I'll just cut out the flex joints and make them solid.
Old May 20, 2008 | 10:46 AM
c3 rolling's Avatar
c3 rolling
i wouldnt, test pipes are weak enough even with flex pipes.
Old May 20, 2008 | 10:49 AM
SuperBlack350z
yeah, it sucks. I think people have better luck with JIC and Tanabe y pipes though but they are a bit pricey.
Old May 20, 2008 | 10:50 AM
BabyZiLLa's Avatar
BabyZiLLa
My engine doesn't move. I bought quality test pipes unlike most people. The flex in the exhaust is from the engine.
With solid mounts I don't see a need for flex joints. I'm not dropping another $500 on a Y Pipe for those flex joints to go bad too.
Old May 20, 2008 | 10:52 AM
SuperBlack350z
if you make replace your flex joints with a a piece of pipe, most likely the test pipes will break...and so on.
Old May 20, 2008 | 10:56 AM
c3 rolling's Avatar
c3 rolling
Its your money, just do it then
sales@czp
Sep 23, 2019 03:30 PM
nanotech
Oct 2, 2015 05:02 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
codek
Sep 28, 2015 03:03 AM
