what is this and what does it do?
what it is the thing that is mounted to the back of the plenum? it has a hose/line that goes to the plenum also. here it is in a pic...
the reason im asking is because i bought a used upper plenum to get polished and the fitting that this line connects to on the plenum is bent and now loose. i can pull it out like an 8th of an inch and slgithly wiggle it. so i just want to know if this this plenum i got is AFU or something i can try to fix with some sillicone or something.
i was thinking i can just use this plenum as a temp while my original good one gets polished if it is jacked up. thanks for looking.
your wrong! That is the plenum head canister 3.5 hose system machine v2 upper plenum solanoid booster.if removed you will throw code sytem malfunction computer brain eco-z-bush-it.now thats long!
