why i change the Y-pipe ?
Old Sep 25, 2008 | 11:54 AM
Darkness75's Avatar
Darkness75
Default why i change the Y-pipe ?
can someone tell me why i change my Y-pipe (the stock one) and keep the mufflers that i have
what will be the gain ? less RASP (stock with HFC is Little raspy)
or HP gain ?
and Q to tony or any one know about MD xyz pipe :
how is it with the stock exhaust ? sound and gain ?
and with the setup that i have will it end the RASP ?
and any videos
Old Sep 25, 2008 | 12:52 PM
twin001's Avatar
twin001
I have resonated test pipes and the XYZ pipe w/ resonated section right now. I also have the stock y-pipe back exhaust (waiting on the VQ from Motordyne). There is very-very little if any rasp with this setup. The XYZ is an excellent y-pipe and the sound is perfect. As far as gains go, look at the Motordyne web page. I did not do a before/after dyno so I can't chime in. As soon as the VQ comes in I'll do a before/after comparison with all stock vs. all Motordyne....and of course, same day, same dyno, same relfash prior to each.
Old Sep 25, 2008 | 01:28 PM
Darkness75's Avatar
Darkness75
thats good news ,thanks
Old Sep 25, 2008 | 03:06 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
or HP gain ?
and any videos
Why you asking us that why you change your y-pipe, ask yourself.
Edit:Here is MD xyz pipe info. There is vid clips and all the good info about xyz pipe.
https://my350z.com/forum/intake-exha...roduction.html
Old Sep 26, 2008 | 07:25 PM
Darkness75's Avatar
Darkness75
i m asking not because there is somthing wrong with main ,,what i meen why some people change to xyz or JIC ,,,,, thats it
Old Sep 26, 2008 | 09:06 PM
singh's Avatar
singh
_______________
People switch to aftermarket y-pipes to benefit from an improved design. A good y-pipe will merge at the optimum point; the point where the most horsepower can be yielded.
Also people will switch y-pipes to match proper inner diameters of the exhaust pipes. IMO, matching the inner diameters of the exhaust pipes is important. Going from a wider pipe into a narrow pipe will result in exhaust gases being interrupted by the transition from a wider diameter to a narrower one. It will also sound bad.
A good match of diameters, for example, my Nismo exhaust and Berk HFCs.
My Berk cats inner diameter (~2.25"):
My Nismo y-pipe inner diameter (~2.25"):
Old Sep 26, 2008 | 10:05 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Much better air flow (designed/bigger pipe), most of aftermarket Y-pipe has 2.5 inlet/3" outlet size. I replaced nismo y-pipe to AAM y-pipe, you can see outside thru pipe ( that make sense?? oh my poor english).
But you need to replace exhaust system for better airflow/power, i do believe just a hfc/y-pipe won't do much untill you replace exhaust system.
Old Sep 26, 2008 | 10:16 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
https://my350z.com/forum/intake-exha...-benefits.html
Old Sep 27, 2008 | 12:59 AM
Darkness75's Avatar
Darkness75
gsingh350Z & xhooniex83 ,,,thank you guys that was very helpfull
for changing the whole exhaust system ,, i just came back to the stock exhaust (i used to run APS 2.5" TD) because of the loss lowend power and the drone kills me although not that high but i hate it , i`ll take my time to go back to aftermarket exhaust again (i hope ther will be one with three NO`s and one Yes) :
NO Loss power
NO RASP (with HFC ,,well i love this mod)
NO Drone
YES Power Gain (i know not much but not lossing at least)
let`s hope ( nismo & Bassani are the most complet but looking for perfict if ther is ) please if i`m wrong about them let me know.
edit : ooh , i just found a thread telling bassani + HFC too much rasp
still hopping
Old Sep 27, 2008 | 05:58 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
2.5 TD is too big size. Go with smaller size.
Me/gsingh350Z we owned nismo.
Old Sep 27, 2008 | 06:09 AM
Because a after market Y-pipe is more pretty.
lapham3
Oct 7, 2022 03:15 PM
