nismo exhaust fitment question
Old Oct 14, 2008 | 08:14 PM
joluis's Avatar
joluis
Default nismo exhaust fitment question
does anyone know if i can use the stock y pipe on the nismo exhaust and also will it sound the same?
Old Oct 14, 2008 | 08:47 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
yes, you can use stock y-pipe. it should sound more louder.
Old Oct 14, 2008 | 08:53 PM
joluis's Avatar
joluis
ok thanks
Old Oct 14, 2008 | 10:07 PM
JonnyC's Avatar
JonnyC
Well, it won't sound as loud as if you put an aftermarket y-pipe on. But if all you are asking is if you replace the mid-pipe and canister with the Nismo pieces, will it be louder? It most definitely will. But that stock y-pipe will help keep it a little bit quieter than if you went with the full cat-back.
Old Oct 15, 2008 | 10:15 AM
joluis's Avatar
joluis
i have the rest of the nismo exhaust but not the y pipe thats what i was asking, so i wanted to know if the exhaust would fit with the stock y pipe and will it still sound the same
Old Oct 15, 2008 | 07:55 PM
joluis's Avatar
joluis
so it would bolt straight on to the stock y pipe
Old Oct 15, 2008 | 08:00 PM
JonnyC's Avatar
JonnyC
Yup, it will bolt up just fine. Just might be a little quieter, and have a tad less performance.
Old Oct 15, 2008 | 08:01 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
yes
Old Oct 15, 2008 | 08:17 PM
joluis's Avatar
joluis
ok can i use the stock gasket or do i need to buy some nismo gaskets
Old Oct 15, 2008 | 08:26 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
I"m using nismo gaskets.
Old Oct 15, 2008 | 08:45 PM
scmtkings4's Avatar
scmtkings4
man i didnt want to make another thread because this falls in close enough. sorry OP
WHAT can i do to make the nismo exhaust sound a little louder? Man it is too damn quiet and i dont want to be driving at 3k+ rpm all the time just to hear something.
i already have berk hfc on with it. I was considering test pipes but i wont be able to pass emissions. and i dont want to get another exhaust. Removing resonator from mid pipe??
oh yeah OP, you can use stock pipe. going from a smaller pipe to a larger pipe shouldnt hurt
Old Oct 15, 2008 | 08:51 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
^ No choice, get the new exhaust. If you don't like them lmk i will trade my nismo later.
Old Oct 15, 2008 | 08:55 PM
joluis's Avatar
joluis
can i use the stock gaskets
Old Oct 16, 2008 | 09:37 AM
JonnyC's Avatar
JonnyC
OP - you can use your stock gasket between the stock y-pipe and Nismo mid pipe. However, you need a new 3" ring gasket between the mid-pipe and canister. This comes with the Nismo gasket set, which is $75. My friend was able to find a 3" ring gasket from Napa that worked.
Old Oct 16, 2008 | 09:38 AM
JonnyC's Avatar
JonnyC
Seriously? HFC's with the full Nismo exhaust is loud. You must be looking for something that is stupid loud. Don't hack an awesome sounding exhaust. Just sell it and get something different that will **** everyone off.
Old Oct 16, 2008 | 11:20 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
^ I defi understand 'scmtkings4''s post. Even mine sound isn't loud enough, well sounds perfect at wot and on highway driving, but under 3 rpm sounds like stock.
Old Oct 16, 2008 | 11:22 AM
scmtkings4's Avatar
scmtkings4
yeah it is loud, but after you hit 3k or more. i live in an area where there is always traffic or just lights. So most of the time im cruising around at 2k rpm and its almost inaudible. I can hear more with stock exhaust at 2k. Maybe its different from outside i dont know
you prolly wouldnt know i was there if i was just gliding by at 2k. i was expecting a bit more 'sound' in the lower range
hoonie what do you have? just nismo? test? hfc?
Old Oct 16, 2008 | 11:29 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
yeah it is loud, but after you hit 3k or more. i like in an area where there is always traffic or just lights. So most of the time im cruising around at 2k rpm and its almost inaudible. I can hear more with stock exhaust at 2k. Maybe its different from outside i dont know
Header/HFC/nismo
https://my350z.com/forum/intake-exha...und-clips.html
I'm same as you, i don't even get on highway that many times.
Old Oct 16, 2008 | 11:44 AM
scmtkings4's Avatar
scmtkings4
man if you think your set up is quiet
how much difference did you headers make? gains wise i hear its not that great what about sound? Only thing deferring me from headers is the $$$ to hp ratio.
Maybe i should switch out my y pipe too. JIc i guess is my next step
Old Oct 16, 2008 | 12:45 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
^ I put all the things at one time, so i have no idea headers gives me more sound.
