installed non foulers and still got SES
Old Oct 21, 2008 | 03:41 PM
matix101vz's Avatar
matix101vz
Default installed non foulers and still got SES
i just installed my resonated test pipes with a set of non foulers and i got a check engine light after about 500 miles. i have an 03 performance. how can i fix this?
Old Oct 21, 2008 | 07:10 PM
Escobar's Avatar
Escobar
try resetting the ecu, if that doesn't help you may have a damaged sensor. In my 03 I didn't use nonfoulers and didn't get a cel
Old Oct 21, 2008 | 07:43 PM
There may not be a fix.
Old Oct 21, 2008 | 07:58 PM
matix101vz's Avatar
matix101vz
may not be a fix as in, the only way to get rid of the light is to put the cats back in
Old Oct 21, 2008 | 10:09 PM
Mazinger Z's Avatar
Mazinger Z
Try checking the code. When I installed mine, one sensor was jacked so I had to buy another. Now no light.
Old Oct 21, 2008 | 10:24 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
+1 free @ local autoshop.
Old Oct 22, 2008 | 04:12 AM
matix101vz's Avatar
matix101vz
ok, the guy who sells the non foulers on here ... are they good?
Old Oct 22, 2008 | 04:57 AM
Reality350's Avatar
Reality350
Your '03 is throwing a code
As mentioned above, have you tried resetting the ecu?
And yes,
Zexy's Non Foulers work well.. I purchased a set for myself when I ran TP's and I did not throw a CEL.
Old Oct 22, 2008 | 09:07 AM
matix101vz's Avatar
matix101vz
yea, i thought 03s are not suppose to thro a CE:, i didnt check what the code is yet tho, but im guessin its the test pipes .. would u get a check engine light if there is low oil in the car?
Old Oct 22, 2008 | 11:19 AM
gothchick's Avatar
gothchick
Might try putting some stainless steel pot-scrubber mesh (Choreboy) inside the non-fouler. Has helped some people with persistent codes. Or try adding another non-fouler to the stack...
Old Oct 22, 2008 | 01:53 PM
OCG35's Avatar
OCG35
how much was it? I'm having issues and might be a bad sensor...
Old Oct 22, 2008 | 02:27 PM
Escobar's Avatar
Escobar
like $50
Old Oct 23, 2008 | 11:13 AM
Zexy? Yes. Bought mine months ago. Good quality. Good fit.
Old Oct 31, 2008 | 01:05 AM
Berk_Technology's Avatar
Berk_Technology
Work most of the time, but they aren't 100% fool proof. CEL's pop on 100% stock cats from time to time as well.
+1 on the stainless steel wool trick. Use 434 fine stainless steel if you have a source for it.
Old Oct 31, 2008 | 06:47 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Did you implement a fix?
Old Oct 31, 2008 | 08:33 AM
Mazinger Z's Avatar
Mazinger Z
I bought it off a member on here for around $50-$60.
Old Nov 23, 2008 | 03:44 PM
matix101vz's Avatar
matix101vz
brillo pads worked great
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
