My Z feel slower after Skunk2 spacer install
Old Nov 5, 2008 | 03:33 PM
weberNL1805's Avatar
weberNL1805
Default My Z feel slower after Skunk2 spacer install
hey guys, for some reason my car feels a lil slower after i installed the skunk2 spacer. Has anyone had this same problem or is it all in my head? Thanks everyone!
Old Nov 5, 2008 | 03:34 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
most likely in your head but check for vaccum leaks.
Old Nov 5, 2008 | 03:35 PM
t0mills's Avatar
t0mills
Re-torque every bolt that you touched, then reset the ECU.
-Tim
Old Nov 5, 2008 | 03:52 PM
weberNL1805
I dont believe there is any leaks....because the idle would be off. It runs just fine... Or doesnt the motor care..?
Old Nov 5, 2008 | 03:55 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
it matters get a can of carb cleaner and spray all the way around the plenum if the idle increases at all you have a leak
Old Nov 5, 2008 | 04:53 PM
weberNL1805
yeah...thats what i was thinking with the carb cleaner. Has anyone else had that same problem with stunk2 with loss of performance. Im thinking it maybe just 2 big of spacer.
Old Nov 6, 2008 | 05:45 AM
gothchick's Avatar
gothchick
^ Yeah. Too big of a spacer. Law of diminishing returns at play.
Old Nov 6, 2008 | 10:19 AM
Kingofvacuity's Avatar
Kingofvacuity
Yeah, there was loss of power with that spacer.
Try selling it and seeing if you can find a powerlabs or a motordyne spacer in the market place?
Old Nov 6, 2008 | 01:09 PM
weberNL1805
Is there any dyno charts to back it up?
Old Nov 6, 2008 | 01:46 PM
robbinsj's Avatar
robbinsj
-Tim
How do you reset the ECU?
Old Nov 6, 2008 | 07:34 PM
Kingofvacuity
You can either unplug the terminal on the batter overnight, or do the pedal method.
Old Nov 6, 2008 | 07:35 PM
Kingofvacuity
There's actually quite alot of dyno charts to back up the gains for the powerlabs spacer and the motordyne. I'd recommend not going over 5/16th
