Is the a big difference between reg iso thermal and copper iso thermal plenum spacers
Old Nov 16, 2008 | 04:54 PM
Silver_Z33's Avatar
Silver_Z33
Default Is the a big difference between reg iso thermal and copper iso thermal plenum spacers
I'm gonna get a plenum spacer and thenismoshop.com has a sale with free shipping on them and the price isnt that big of a difference between the iso thermal and copper iso thermal spacers. Is there a big difference in performance as far as heat soak or not?
Old Nov 17, 2008 | 03:16 AM
Subninja's Avatar
Subninja
I think the Iso Thermal is better at not heat soaking so badly. Get the iso thermo spacer
Old Nov 17, 2008 | 04:25 AM
Big. Very big.
Old Nov 17, 2008 | 05:13 AM
halcyon901's Avatar
halcyon901
i was told there wasnt that big of difference, unless you live in a very hot climate
Old Nov 17, 2008 | 05:16 AM
Silver_Z33's Avatar
Silver_Z33
well, im on long island ny, should i just go with the reg iso thermal then or the copper?
Old Nov 17, 2008 | 06:38 AM
halcyon901's Avatar
halcyon901
well, i went with the basic 5/16" spacer, i think thats all you need
Old Nov 17, 2008 | 07:01 AM
Hokie Z's Avatar
Hokie Z
the iso thermal helps with heat soak, but get the copper if it gets really cold in your area. So in NY, get the copper iso thermal
Old Nov 17, 2008 | 07:57 AM
Motormouth's Avatar
Motormouth
I think you (and some others on here) are confused as to what the 'copper' and 'non copper' parts are.
the iso thermal spacer is the same for both kits. 'iso thermal' relates to the Aramid material the gasket is made of.
The 'copper' is actually a copper throttle body plate that has a coolant tube connected to the top of it. you then reroute the coolant from the plenum through this to keep intake temps down, while still getting the throttle body up to temp so it doesn't stick in cold weather.
the 'non-copper' uses a bypass valve that you splice into the coolant line to the upper plenum that you can open and shut to control the coolant flow. I wasn't aware they were still making this kit. They both will work, but the copper bypass is the better kit because you don't need to adjust it.
I know motordyne's website probably explains all of this, I would look there.
let me know if you have any questions.
Old Nov 17, 2008 | 08:38 AM
Silver_Z33's Avatar
Silver_Z33
thanks motor that helped me alot, im gettin the copper one
Old Nov 17, 2008 | 09:34 AM
Motormouth's Avatar
Motormouth
that is the kit I have. super easy install and worth the extra few bucks. I don't like the idea of cutting my hose, if I ever need to take it all off for some reason.
Old Nov 17, 2008 | 10:43 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
good response
Old Nov 17, 2008 | 11:24 AM
Silver_Z33's Avatar
Silver_Z33
Originally Posted by 2004Black350z
good response
lol ari gold is the man
Old Nov 17, 2008 | 04:18 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
I would have chimed in here but Motormouth explained it to a T.
Old Nov 17, 2008 | 07:25 PM
Hokie Z's Avatar
Hokie Z
yeah i didn't really explain that well lol, thanks motormouth. I also have the copper kit, definitely easy to install
Old Nov 17, 2008 | 07:40 PM
shakuya88's Avatar
shakuya88
Getting a copper kit soon. Gotta love a New England winter
Old Nov 18, 2008 | 05:44 AM
Motormouth's Avatar
Motormouth
what I want to understand is how I have a higher iTrader rating than you :P
Obama is already distributing **** around! lol
350z82
Oct 1, 2015 06:25 PM
