DIY Request: Test Pipe Install
Old Dec 8, 2008 | 03:16 PM
pfregeolle's Avatar
pfregeolle
Default DIY Request: Test Pipe Install
Hey guys, I know I'm not supposed to post DIY Requests in the DIY section, so Im asking here.
I know that this install is pretty straight forward, but I want to make sure I don't eff stuff up. So could anyone give me some pointers? I have the bolt penetrator on the bolts right now, soaking. And I already pull off the two nuts that bolt the cats to the y pipes.
I am having trouble getting to o2 sensors out, and I was just wondering what the best way is to do it? I have heard that you have to be very careful with them when pulling them out. Please let me know if you have some tips. Also I should not spray penetrator on them right?
Also, there is a third bolt and nut that I have to get to on the header to cat pipe connection. Is there a trick to getting to it? Or just squeeze myself around it?
Thanks! Im going to float around the site for a few minutes until I see some replies, and search for other threads as well. Thanks guys!
-Paul
Old Dec 8, 2008 | 05:15 PM
OldDirty Z33's Avatar
OldDirty Z33
I would say its pretty much easier than changing the brakes
Old Dec 8, 2008 | 05:31 PM
BERTO's Avatar
BERTO
I've done my testpipes like 780561316540650 times. here are some tips.
1: Get a super long extension and you will be able to reach the bolts that go from the headers to the cats through the engine bay on the passenger side. On the drivers side you should be able to get 2 of them and the one on the very bottom you will need to get under the car.
2: Buy new gaskets.
3: Put everything in place with the bolts finger tight. When everything looks good tighten them down.
As for the sensors you can buy a specialty socket to get them out without damaging the wires. They are about $10-$13. Also, use anti-seize on the threads so that they can be removed in the future.
Old Dec 8, 2008 | 06:04 PM
pfregeolle's Avatar
pfregeolle
Yea I got all the bolts off expect for the one super beeeyotch one on the driver's side thats highest to the engine bay, and like guarded by every single possible hose and wire around it. Ughhhhhhh what a pain, I thought this would be easier than it's turning out to be. I had to take a short break, but after I get this last bolt, I'll be good to put the new stuff in place. I'm going to try to get to the one bolt from the engine bay, so far I've gotten the rest of them from underneath the car. Woooo....here we go.
Old Dec 9, 2008 | 09:12 AM
Chaser720's Avatar
Chaser720
Lemoned Z
2: Buy new gaskets.
I just used an open ended wrench for the sensors. It was definately a PITA but its doable.
Old Dec 9, 2008 | 12:39 PM
BERTO's Avatar
BERTO
The first time I did them it felt like forever. But after the 3rd time it's a breeze. It takes me about an hour and a half from start to finish.
Old Dec 10, 2008 | 05:38 PM
Remove catalytic converter from car.
With the catalytic converter OFF the car then remove oxygen sensor.
Old Dec 10, 2008 | 05:39 PM
Old Dec 11, 2008 | 05:43 AM
pfregeolle's Avatar
pfregeolle
^Wish I had had that o2 sensor tool, but my friend and i were able to pound down the heat shield around them on the cats, and fit a 22mm open ended on there and knocked em out. Took forever, but I finally got it done!@#$%!!!!!1111
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
