Exhaust Install HELP **Pics**
Ok so I am trying to install the TURBO XS EXHAUST, I know a couple members had a problem aligning the Y-pipe flanges to the two cats. Unfortunately, I am having this problem right now. Can anyone tell me what they did to align the Y-pipe please?
I hope you're not bolting (and tightening) one side down first and then doing the other side. Hook both sides with the bolts then tighten both sides progressively (so you relieve any tension and unnecessary force on the flanges and their welds). If you keep forcing it, you can also break the welds (not too likely, but can happen). In addition, if and when you do get everything bolted, keep in mind that the pipes are under constant pressure (as you had to force them into place). So, if you race, the welds will give sooner or later. Perhaps you should visit a muffler shop to heat the pipes a little (you'll have burn marks on the pipes, though) so the metal gets a bit softer.
I've broken 3 test pipes (even after rewelding with stronger welds) so far.
