test pipes and oil consumption?
Old Jan 31, 2009 | 11:36 AM
Raginraj11's Avatar
Raginraj11
Default test pipes and oil consumption?
I had the strup test pipes installed without the non-foulers (SES light was on) paired with my Fast Intentions exhaust. I started noticing that my car was taking more oil than usual. At one point there was barely any oil in the engine and i had to top it off with 4 more quarts and I had gotten an oil change about 500 miles ago. I dont see a correlation between oil consumption and test pipes but the problem disappeared after i had the test pipes removed and had the stock cats put back on. Anybody have an idea as to whats going on?
Old Jan 31, 2009 | 12:41 PM
singh's Avatar
singh
_______________
wow if you are losing more than 4 quarts dude that's definitely something you should get checked out be the dealership..
I doubt it is the test pipes because many people run test pipes and I have never heard of anyone burning 4 quarts of oil. I bet you have a leak or something..
Old Jan 31, 2009 | 12:46 PM
Raginraj11's Avatar
Raginraj11
yea im having the oil consumption test done right now. There wasn't any leak so im guessing it could be something internal?
Old Jan 31, 2009 | 02:46 PM
That's because there is none.
Old Feb 2, 2009 | 05:04 AM
2fast4ya's Avatar
2fast4ya
I have serious oil consumption as well, it did not start until i got HFC's
and then it got worse when i got test pipes-i went to the dealer and they
said it is my fault-they said the mods i have done caused it to run too rich
and dilute the oil with fuel causing it to burn off. i have zero leakage on
ground or under the car and no smoke-it does make some fumes on cold
start from no cats. my car normally uses about 2 1/2 qts or more between
3k mile oil changes with amsoil full synthetic.
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
