Do air inlets actually make power?
Old Feb 12, 2009 | 04:44 PM
Subninja's Avatar
Subninja
Default Do air inlets actually make power?
So I have looked on the forums and I have looked on the web. Does anyone have a before and after dyno of someone who installed one of those air inlet ducts like this.
I mean the idea behind it seems sound but I would like to see some proof behind the pudding you know.
Also if you installed on afterwards what was your impression besides other mods.
I don't really care for the look, but it isn't bad and if it works it is functional which is what matters to me.
Old Feb 12, 2009 | 05:01 PM
DavesZ#3's Avatar
DavesZ#3
Probably not enough that you could ever measure. Air already passes behind the bumper to the inlet of the OEM airbox. All the front duct does is shorten the path a little more.
Old Feb 12, 2009 | 05:04 PM
Z You Later's Avatar
Z You Later
well to think of it this way...it's for looks BUT a little extra air in the engine bay DOES help, you just won't notice any real difference
Old Feb 12, 2009 | 06:23 PM
FORZWIN's Avatar
FORZWIN
The problem with measuring something like that, is that when on most dyno's they simply put a fan in the grill to keep the car from overheating. To properly test something like that requires air to be directed into the duct.
I've been running one of these for about a year now,
I'll say that I noticed the gains from highway speeds onward. It just seemed to pulled harder from 60+. Is there any merit to this? No. My butt dyno is horribly inaccurate and most likely doesn't share the same calibration as yours. IMHO, do it for looks, the Z has one of the better stock airboxes on the market and provides a good location for aftermarket air filters. I would consider it a visual enhancement, but personally, I wouldn't cut a hole in the bumper...
Old Feb 12, 2009 | 09:16 PM
No. Its a piece of plastic. Pieces of plastic don't make power. Motors do.
Old Feb 13, 2009 | 09:56 AM
2fast4comfort's Avatar
2fast4comfort
ram air makes a difference on bikes, but the revs are lower the tube is longer and it wasnt designed with that in mind so i have no idea
Old Feb 14, 2009 | 01:31 PM
onagao's Avatar
onagao
This is actually something that I've been wondering for some time. I'd love to see some test results or something along those lines.
Old Feb 14, 2009 | 05:10 PM
350z2go's Avatar
350z2go
true dat
Old Feb 15, 2009 | 12:46 PM
Spork's Avatar
Spork
I have the supplied Nismo V2 air duct installed. Does it make a difference? Meh... I'd like to think it brings an extra amount of air into the hole to deliver some extra air to the bay, hopefully allowing heat to dissipate a little easier.
Old Feb 15, 2009 | 02:18 PM
Ruthless18x's Avatar
Ruthless18x
I agree with nothing noticeable. Probably does increase the air flow though in circumstances.
Old Feb 16, 2009 | 08:45 AM
Q45tech's Avatar
Q45tech
Measure the pressure above the normal 14.7 psi [sea level] in front of MAF with a manometer [one that accurate in 0.1" H2O increments].
1.0 PSI = 27.7" H20
The problem is the engine is already supplied with 14.7 psi [29.92126" HG] of atmospheric pressure..........................why a supercharger with 1.00 PSI of boost only adds 6.8% more air.
"The pressure build-up can be defined using the Pitot-static tube theory:
P = .5 x r x v2
Pressure (P) is force divided by an area. In the English system of measurement the units of pressure are (lb - force)/in2 which translates to psi. Density (r) is mass divided by volume. The units of density in the English system are (lb - mass)/in3. Velocity (v) is air speed, with units ft/sec. Plotting pressure vs. speed gives a graph that has theoretical pressure rising with the square of speed, and this is why ram air has much more effect at greater speeds. For a speed of 150 mph, the resulting maximum theoretical pressure would be about 27mb (approximately .4 psi). "
So at 150 mph a well designed duct could increase air flow into engine by 0.4 x 0.068 or 2.72%
Old Feb 16, 2009 | 02:58 PM
foreveryoung's Avatar
foreveryoung
1.0 PSI = 27.7" H20
P = .5 x r x v2
At 150 Mph a poorly designed air duct could cut airflow any amount.This is a duct designed to fit in a specific area,not one designed for a mathematic equation as beautiful as this.
Old Feb 17, 2009 | 02:34 PM
1.0 PSI = 27.7" H20
P = .5 x r x v2
That what I was thinking!
Old Feb 17, 2009 | 06:28 PM
twitch579's Avatar
twitch579
Post
1.0 PSI = 27.7" H20
P = .5 x r x v2
Those were my thoughts exactly also.
Old Feb 19, 2009 | 05:32 PM
Q45tech's Avatar
Q45tech
Actually not, as even a very poorly designed duct will still be pressurized by the 14.7 psi.
Now if the area of the duct were smaller than the MAF it would start to offer some resistance but even a 2-3" hole would be pretty insignificant due to small displacement of engine.
215 ci/2 = 107ci per rev x 6000 rpm = 642000/1728 = 371.5 CFM max and usually more like x 0.85 = ~ 315 CFM.
Old Feb 20, 2009 | 06:17 AM
dryseals's Avatar
dryseals
1.0 PSI = 27.7" H20
P = .5 x r x v2
Interesting.
But what are we looking at here, pressure or flow? If I take a volume say 200 cc and lower the pressure to 1"Hg and then open a 1.9" dia valve at a given slope time, how fast will the volume fill to atmosperic pressure? Will a few inwc of pressure speed the process?
If I have a filter that causes a 2"wc drop across it an I increase the incoming pressure by a couple of inches, would I see more flow across the filter and thus more flow to the engine.
There are far to many unanswered variables here to make a blanket statement that seems to push the pressure advantages of a moving vehicle out the window.
Old Feb 21, 2009 | 01:20 PM
Subninja's Avatar
Subninja
Like I said the general idea of ramming air into the engine from the cars momentum seems to work in theory, but I wish there was data to support it. Then again I am sure if it did work the original design of the Z and the GTR would have used it.
Old Feb 21, 2009 | 07:58 PM
Steve-O Z33's Avatar
Steve-O Z33
My car gets more unwanted attention than power gains with the Varis duct.
Old Feb 22, 2009 | 07:45 AM
foreveryoung
The pressure has little to do with actual air flow.Turbulance,laminar,reversion,valve overap etc all affect air flow from its point of origin.Consider an intake port of a cyl head.We already know that bigger ports seldom flow more.Port design,angles,short side radius,laminar qualities,air speed all affect the actual flow.Every port will eventually reach a limit and start to flow less air at higher speeds due to these factors.This fact is what truly limits an engines HP.
Old Mar 1, 2009 | 10:29 PM
bigmack000's Avatar
bigmack000
http://autospeed.com/cms/A_0629/article.html
read this and all the articles at the bottom
they do it on a turbo car but the info can transfer over to NA cars
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
