iso thermal gasket HELP!!! DONT WANA GET RIPPED!!
Old Mar 20, 2009 | 02:22 PM
ztarded's Avatar
ztarded
Default iso thermal gasket HELP!!! DONT WANA GET RIPPED!!
hey guys i recently ordered a motordyne iso therm 5/16 spacer off ebay and the dumbass didnt send the iso thermal gasket that goes on the lower collector along with the white spacers that go under the plenum. well i got a $50 refund from the guy to cover a new bolt kit and he is shipping the iso thermal gasket but i am a lil suspicious cuz he said the mechanics must have kept it then he siad he found it and is shipping to me. my question is how can you tell the diffrence between the stock gasket and the iso thermal gasket?? i think this bastard might try to send me a stock gasket just so i can close my paypal dispute.. any help is appreciated THANKS
Old Mar 20, 2009 | 06:12 PM
ztarded's Avatar
ztarded
dang, all these people with this exact spacer and no one knows the diffrence?? sombody has to know.. moderators??? anybody at all????
Old Mar 20, 2009 | 06:57 PM
stormcrow's Avatar
stormcrow
if you're speaking of the Aramid gasket that sits between the lower collector and the intake, then I am not sure if there is any way to tell the difference. i think the colouring might be a bit dissimilar. you could always PM Hydrazine (Tony with Motordyne) and i'm sure he can answer your question. great guy to work with, so don't hesitate.
Old Mar 21, 2009 | 01:00 AM
ztarded's Avatar
ztarded
thanks man really appreciated.. bout to hit him up now!!
Old Mar 21, 2009 | 12:07 PM
350z-Jim's Avatar
350z-Jim
Mine didn't look that much different from the stock gasket that I can remember now... Motordyne should be able to tell you I would think.
Old Mar 22, 2009 | 10:30 AM
tylerxfire's Avatar
tylerxfire
pretty sure they are the same basically...i don't think it would matter honestly, but talk to motordyne
u should have just got a new one
Old Mar 23, 2009 | 08:01 AM
zero degrees's Avatar
zero degrees
your stock gasket is metal and the one you will get from motordyne is a paper/cardboard type that you cover in oil and when it is heated will swell and insure no leaks.
as for missing the spacers, you should get those as the help you upper intake seat to the lower intake.
Old Mar 23, 2009 | 08:31 AM
Asian Invasian's Avatar
Asian Invasian
You should have bought a new one from Tony at Motordyne here is an awesome vendor.
Old Mar 23, 2009 | 09:05 AM
stormcrow's Avatar
stormcrow
my stock gasket on my old '05 G35 wasn't metal...
but, this thread = dead. OP has already spoken with Tony. /thread plzthxkaibai.
Old Mar 23, 2009 | 09:06 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
The Aramid gasket is quite different from the stock gasket.
The Stock gasket is a rigid black metal crush gasket and is about 0.020" thick.
The Aramid gasket is a gray, dense nitrile impregnated gasket that is about 0.0625" thick. Its soft and flexible.
Tony
Old Mar 23, 2009 | 09:07 AM
Hydrazine's Avatar
Hydrazine
What was it? I only know of one kind of gasket Nissan makes and its metal.
Old Mar 23, 2009 | 10:18 AM
stormcrow's Avatar
stormcrow
it was very similar to the ones you send. i noticed when removing the original that it was a slightly different color (lighter) than the one you sent with my MRev... it required some scraping to remove, so it certainly wasn't metal... it may not have been OEM, as i was the second owner of the car...but, i highly doubt it was aftermarket as the car had no mods and only 8k on the odometer...
this was years ago, though...so my memory might be a bit skewed...
Old Mar 23, 2009 | 07:02 PM
OCG35's Avatar
OCG35
Tony
Tony, have there been any changes since the one after the beta-test version?... I swapped the beta for version 2 a few yrs back... I'm doing some cosmetic mods in the engine bay (including minor plenum stuff) and figured I'd take a look at how the gasket is holding up while things are apart... if there is a newer version (other than the one replacing beta version) I might as well install it while I'm there.
Also, is the Aramid gasket "soft and flexible" after long-term use?
Old Mar 23, 2009 | 07:16 PM
Hydrazine's Avatar
Hydrazine
Yes, it changed after the beta version. And yes, they stay soft and flexible after long-term use.
Old Mar 23, 2009 | 07:21 PM
OCG35's Avatar
OCG35
I have the first change (after beta) - I'm wondering if there have been any other changes since then?... I'll take a look at it this weekend and order a new one if needed - in fact, maybe I'll order one anyway just to have it so I dont have to re-do later... can you PM price for gasket only ~
burglapfd
Dec 6, 2020 01:04 PM
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
_koubie_
Sep 20, 2015 06:34 PM
