Berk metallic high-flow cats broke apart after 13 months of use (N/A)
Old Apr 17, 2009 | 07:19 PM
mthreat's Avatar
mthreat
Thumbs down Berk metallic high-flow cats broke apart after 13 months of use (N/A)
I got Berk high-flow cats in September 2007. I spent the extra money to get the metallic ones so they would last longer, and be okay on the track. I talked to a guy at Berk on the phone, told him I was replacing the Crawford non-metallic ones because they had come apart. He said they would be good. BTW my engine is N/A.
Last week I heard a rattling sound, which I traced down to the driver-side cat. So I removed it and sure enough, the core thing on the inside had broken and slammed against my stock O2 sensor. See the attached photo of the cat element -- see that round indentation? That is from my O2 sensor.
It gets better. I took off the passenger-side cat, so I could put my stock cats back on temporarily. After I removed it, I realized it was completely hollow. It, too, had come apart sometime and I hadn't realized it! Note that my car was in the shop with the engine out from October 4, 2008 until March 2009, so this happened after only 13 months of actually running the cats.
I emailed berk twice (two different email addresses), explaining what happened, and I got no response. If you look at my posts on this forum, you can see that when a vendor gives me good customer service, I like to tell others about it. (here's an example). Some of my favorite vendors are SPL parts, Z1Auto, Kyle at Import Parts pro, and Uprev, just to name a few. I rarely get a crappy product or bad service, but now I have, and this is my post. I spent like $400 on those, I would expect them to last longer than 13 months. Oh well. if anyone wants some pre-gutted berk cats in Austin, lemme know.
So for now I'm giving up on cats. I just ordered some Kinetix resonated test pipes from Import parts pro. And I'm done with Berk.
Old Apr 17, 2009 | 07:24 PM
Cali-Darkness's Avatar
Cali-Darkness
Did you try to PM them on here?
Old Apr 17, 2009 | 07:25 PM
tranceformer95's Avatar
tranceformer95
Don't take this the wrong way but..
I know your car is NA but is it running OK? Has it been tuned? It might just be bad luck but I just find it a bit odd that in two years you've destroyed two sets of cats?
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
Dayum. That would **** me off. I had the Helix test pipes when they first came out, and now I'm testing out the Top Speed resonated pipes. Never wanted to spend the money on hi-flow cats, and now I know why. I keep reading about bad experiences like yours.
Nismospeed4life's Avatar
Nismospeed4life
I am glad to see this thread because I was about to purchase the Berks HFC tomorrow. I guess that wont be happening. Fast Intentions anyone?
Old Apr 17, 2009 | 07:32 PM
Thats not good. 13 months gives me little information. How many miles is that?
Old Apr 17, 2009 | 07:33 PM
WhiskeyHotel's Avatar
WhiskeyHotel
That cat looks like it got too hot to me. My guess is that too much fuel is blowing out your tail pipe. Ditto on the above post - check your tune.
godmans's Avatar
godmans
did you notice misfire like engine rattles at stoplight after some highway or "intensify" driving?
Old Apr 17, 2009 | 07:34 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
That is really short time. Sorry to hear man.
Old Apr 17, 2009 | 07:36 PM
Nismospeed4life
Kyle from Import Pro is an awezome vendor... I was wondering though, will the Kinetix resonated test pipes throw the check engine light? It says it does not, however I was just wondering how true that is? If they really dont, I want them to.
1cockyZ's Avatar
1cockyZ
This exact same thing happened to my stock cats after I gutted the secondary element and left the upper metal element in. One came apart and the other was just gone. Although I did drive the car with a broken piston for a while.
Old Apr 17, 2009 | 07:42 PM
mthreat's Avatar
mthreat
Fair question. Yes, it's been tuned at Uprev, the Air/Fuel ratio is good, not too rich (which can cause cats to come apart - especially on turbo engines). Uprev is like 2 miles from my house and I'm up there quite a lot.
From my spreadsheet of 350z mods:
10/1/2007 64,800 miles - Berk metallic high-flow cats - cost: $400
My odometer TODAY shows 78800. Last october it showed 75500. So it was 14,000 miles for the 2nd cat to come apart. The first one I don't even know when it came apart, probably before last october.
I was at the track last Sunday, and I noticed the exhaust note changed a bit halfway through the day, which concerned me. I didn't notice the rattle until a few days later.
I had Kinetix high-flow catalytic converters. Lasted 19,206 miles before failing inside. Rattled like a SOB. Good luck.
Old Apr 17, 2009 | 07:44 PM
mthreat's Avatar
mthreat
I have a 2003, which are known for practically NEVER throwing a check engine light for test pipes or high-flow cats. I've never had the CEL for it. For 2004 or later models, I don't know.
Old Apr 17, 2009 | 07:46 PM
Dang you keep a spreadsheet. 14,000 miles stinks. Pipes are either falling apart inside or cracking on the outside. You cant win.
Sean's Avatar
Sean
If mine fails I will find a Flowmaster that can be welded in place.
Old Apr 17, 2009 | 07:50 PM
Nismospeed4life
Have you installed the Helix test pipes already? If so. how do they sound? Do you like them?
Old Apr 17, 2009 | 07:51 PM
tranceformer95
Ah, UpRev, good stuff. I'd say this is bad luck then.
Ray (had his last Z tuned by UpRev too)
Old Apr 17, 2009 | 07:53 PM
Nismospeed4life
qftmft!
Old Apr 17, 2009 | 07:58 PM
SmoothZ's Avatar
SmoothZ
I had them on my 03 for years and didn't mind the sound unlike most people. I equated the sound to something that belonged on a track.....
