HFC and P1168??
Old Apr 30, 2009 | 01:46 PM
JWS82's Avatar
JWS82
Default HFC and P1168??
Sorry guys if this has already been discussed, but I searched and couldn't find any answers.
I recently had my Berk HFC installed on my HR this past Friday and upon starting the car, voila: SES light. No biggie at first because I've heard some HR owners have this problem. Well I go get the code checked out but it's not the usual 0430 or whatever, it's a P1168 (closed loop, bank 2). From what I understand, this is the O2 sensor, pre cat? Is it possible that it was damaged during install? The damn impact tools rattled the shiet out of my car.
Second, does this pre-cat sensor affect the way the car runs? It ran fine for a couple of days and now all of a sudden, the exhaust sounds totally different and when I go WOT, it lurches before taking off (like it went into limp mode??)... it didn't do this when I first installed the HFC. Any input would be greatly appreciated.
Old May 1, 2009 | 12:29 PM
JWS82's Avatar
JWS82
Here's an update, just wanted to share with everyone in case others have this problem in the future.
Talked to Bryan at Berk and it seems the P1168 (closed loop bank 2) is most likely a damaged primary O2 sensor (pre-cat/header, driver side) and it was probably damaged during install (damn impact tools). This sensor apparently DOES affect the way the car drives since the ECU cannot tell whether the car's running rich or lean on that side and thus puts it into "limp" mode to avoid damaging the motor. The 1168 is what also caused the subsequent P0051 error as well. Getting the sensor replaced on Monday and I should be golden. I'll update once that's done in case anybody else has this problem in the future.
On a sidenote: Bryan and Berk Technology.. you guys are awesome. By far the BEST customer service I have every experienced. Keep up the good work
Old Apr 11, 2011 | 06:08 PM
USMarIne89's Avatar
USMarIne89
this thread might be 2 years old but i did the exact same thing installed test pipes and same exact codes what did u do to fix it and did it work please help !
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
disturbed2483
Aug 5, 2009 05:54 PM
AutoStore350z
Mar 13, 2007 06:23 PM
m1james@bellsou
Nov 20, 2006 02:13 PM
bverschage
Oct 24, 2005 07:27 AM
