Crack on my test pipe
Old Apr 4, 2011 | 01:17 PM
Jun's Avatar
Jun
Default Crack on my test pipe
Took my test pipes out and found a crack on them:
I think probably the shop did it when taking them out, since I don't see any damage to the pipes such as scratches or whatnot that could've actually made this happen.
Do you guys know if it's fixable (welding it back together)?
I'm going to sell them but just want to make sure if the guy buying it will be able to fix it or if I can fix it before selling them.
Thanks in advance.
Old Apr 4, 2011 | 01:27 PM
SuperBlack350z's Avatar
SuperBlack350z
you can weld it back together. i had similar crack on my kinetix cats but it was from the exhaust. i doubt it was teh shop that did it.
Old Apr 4, 2011 | 01:32 PM
Jun's Avatar
Jun
I thought maybe when they tried to take out the O2 sensor it was way too tight and the stress caused the crack, that's the only thing that came to mind.
Thanks! Good to know, would've hated throwing these puppies away.
Old Apr 4, 2011 | 01:35 PM
terrasmak's Avatar
Very common and easy to weld up
Old Apr 4, 2011 | 02:52 PM
This is the sensor port? Easily damaged removing the sensor. For $68 it is hardly worth welding: http://compare.ebay.com/like/1806465...=263602_309572
Old Apr 4, 2011 | 02:57 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
+1. Iv cracked 2 test pipes. Had both rewelded and wasnt worth it. Either buy some cheap replacements ^ or quality. It looks like the weld it self around the 02 bung was crappy
Old Apr 4, 2011 | 03:13 PM
plumpzz's Avatar
plumpzz
Check out the aps test pipes.. theyre the beefiest ive seen.
Old Apr 11, 2011 | 06:56 PM
sithlordsoup's Avatar
sithlordsoup
Last time my car was on a shop lift i glanced underneath and saw that the driver side test pipe had a about a 3 inch hairline crack near the 02 bung.
I havent dealt with it since and my car still sounds the same.
Hooray for another megan product.
Old Apr 11, 2011 | 07:25 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I'm on my 5th set of test pipes, as I broke or cracked the previous 4 sets. Rewelding is pretty much a bandaid fix, imo, as they'll crack again.
I've heard good things about APS test pipes, but I'm currently using the TurboXS ones and haven't had any troubles thus far (although I don't drag race anymore).
sales@czp
Sep 23, 2019 03:30 PM
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
