Kinetix Install Ques.-Gasket-
Old Jul 18, 2009 | 06:36 PM
KeithGT's Avatar
KeithGT
Default Kinetix Install Ques.-Gasket-
On the Kinetix V+, it says to re-use the factory gasket ALONG with the gasket that comes on the manifold....AND to use a silicone to seal it.....is the factory gasket really Necessary? And if so, why?
Thanks,
Keith
Old Jul 18, 2009 | 07:38 PM
BlueZ33's Avatar
BlueZ33
when i installed the kinetix on the 03 i had, i only used the the hi temp clear silicone and i didnt have any problems
Old Jul 18, 2009 | 07:45 PM
Z04's Avatar
Z04
Thanks,
Keith
you would think that the people that made the plenum put that in the instructions for a reason. so i'm going to take a wild guess and say yes, it is needed. that is why it is called "install instructions"
Old Jul 18, 2009 | 08:12 PM
2k6-z33's Avatar
2k6-z33
I only used the kinetix gasket and no air leaks.
Old Jul 18, 2009 | 09:01 PM
BlueZ33's Avatar
BlueZ33
only reason i used the silicone was i bought the kinetix from a member on here and the gasket that i had was destroyed, so i called kinetix and they told me that that is what they use along side the gasket, and in my case i would have been fine.
Old Jul 19, 2009 | 06:30 AM
KeithGT's Avatar
KeithGT
How many times have you installed a gasket, on a gasket, then used silicone which is basically another gasket...? Seems like overkill to me.
That and i have no clue where my factory gasket went after i put on my plenum spacer....
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
