Motordyne Product Help!
Old Aug 13, 2009 | 05:47 PM
DMO92784's Avatar
DMO92784
Exclamation Motordyne Product Help!
Today I ordered the motordyne, 5/16" copper spacer today... then read on on another website saying the MREV2 was the prerequesit to the spacer. Needless to say I cancelled the order and tried to order the MREV 2. When I went to order that the guy told me that is useless with out the spacer. Think I should just bite the bullet and buy both.
What are your reviews on these products? How does it change the sound and can you really feel the power like Motordyne says you do.
Old Aug 13, 2009 | 06:02 PM
Sickboy101's Avatar
Sickboy101
this is a very cost effective breathing mod that gives you some good bang for the buck. I found my thottle response improved and increase mid-range power. Please note that you only need the MREV 2 and spacer for 06 rev-ups. All 03-05's just need the 5/16 spacer.
Old Aug 13, 2009 | 06:07 PM
Welcome. Motordyne reviews from 2004 are a great place to start.
Old Aug 13, 2009 | 06:13 PM
DMO92784's Avatar
DMO92784
Yes I have the rev up engine... So since I have the rev up the mrev 2 stills adds hp and tq and is not just a mod you need to get the performance out of the spacer
Old Aug 13, 2009 | 06:21 PM
Sickboy101's Avatar
Sickboy101
you will need both the MREV2 and spacer to notice any HP and TQ gains. The time and labour to install just a spacer is not worth your time or money... get both and you will be very happy with this mod.
Old Aug 13, 2009 | 07:30 PM
rcdash's Avatar
rcdash
He will do just fine with just the MREV2. The time and labor is like 60 mins tops.
Old Aug 14, 2009 | 03:57 AM
Sickboy101's Avatar
Sickboy101
^^ I've had no experience with just running the MREV 2... perhaps you can elaborate for the OP.
I guess if your on a tight budget then the MREV 2 makes the most sense to buy first.
Old Aug 14, 2009 | 04:08 AM
rcdash's Avatar
rcdash
Well from the motordyne website:
MREV 2 Manifold TM - The undisputed king of bolt on power.
A universal manifold modification for use on any VQ35-DE engine. When used with or without a spacer or aftermarket upper plenum, this lower plenum will make substantial power gains.
Multiple independent test show when used with a 5/16" spacer on the revup engine, the combination will add a "minimum" of 15+ HP and 18+ TQ in the upper midrange. Many independent MREV 2 Manifold REVUP tests have dynod in excess of 20HP and 30 TQ in the upper midrange and with high RPM peak power increased by 3-5 HP.
The MREV2 is a prerequisite to the plenum spacer when used on a revup engine. No other normally aspirated VQ modification provides as much gain as the MREV 2 Manifold!
That was easy.
Old Aug 14, 2009 | 04:10 AM
Sickboy101's Avatar
Sickboy101
I think he is looking for actual testimonals
Old Aug 14, 2009 | 06:27 AM
Reality350's Avatar
Reality350
"The MREV2 is a prerequisite to the plenum spacer when used on a revup engine."
-With the revup engine, the OP should get both.
OP,
You really need to search on this product.. this has been discussed to death.
Here is my own testimonial.
https://my350z.com/forum/intake-exha...-bolt-ons.html
Old Aug 14, 2009 | 07:21 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Originally Posted by DMO92784
... When I went to order that the guy told me that is useless with out the spacer. Think I should just bite the bullet and buy both.
If you have the REVUP engine, its the spacer that needs the MREV2 to work.
On the REVUP engine stock lower collector, the spacer by itself does nothing. It does however make good gains when used on the MREV2.
The MREV2 will make good gains by itself when used on the REVUP engine but the top end horse power is improved when a spacer is used on it.
The dyno plot below was from an independent test conducted by forum members.
It shows three conditions:
Baseline, MREV2 and the MREV2 with 5/16" spacer. It pretty much shows everything you need to know about the dyno results.
Just as a note for clarification: The spacer makes good gains all by itself on the 03-06 NON-REVUP engines.
Old Aug 14, 2009 | 02:18 PM
DMO92784's Avatar
DMO92784
Thanks for all the input guys I just bought the spacer and the MREV 2
Old Aug 14, 2009 | 03:13 PM
350ZthatsMe's Avatar
350ZthatsMe
for the Rev ups it seems that the 5/16 spacer doesn't do too much... wondering if it's worthed it... MREV 2 is though...
Old Aug 14, 2009 | 04:06 PM
Hydrazine's Avatar
Hydrazine
I hear you, but it all depends on your objectives.
Some people absolutely require that extra top end power for race applications.
If you race, you generally need to keep the engine near redline for max power. In that condition, it makes a difference.
EDIT: Also note that the scaling on the Y Axis makes the gain look small. There is about a 10HP gain over a good portion of the race RPM band.
Old Aug 15, 2009 | 12:15 PM
DMO92784's Avatar
DMO92784
Just turned my Injen CAI to a short ram sounds a lot better in my opinion cant wait for the spacer and MREV 2, will this make the engine note and exhaust note different?
Old Aug 15, 2009 | 03:06 PM
Hydrazine's Avatar
Hydrazine
It may sound better as a short ram, but if you arent using a heat shield its losing about 20HP due to 150'F hot air ingestion.
Old Aug 15, 2009 | 04:58 PM
350z spd's Avatar
350z spd
+1 on that.. cold air intakes such as the injen are great intakes. short ram intakes take in a lot of heat from under the hood.
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
_koubie_
Sep 20, 2015 06:34 PM
