Borla TD drone
Old Aug 29, 2009 | 06:08 AM
maXmood's Avatar
maXmood
Under Boost!
Default Borla TD drone
i just got it installed along with Berk HFC, and at a certain rpm (1.6k-1.7k and 2.3k-2.4k) i get the drone.
is there a fix available for this? or am i going to have to live with it? or end up removing it .
thnx
Old Aug 29, 2009 | 06:54 AM
Toby-22's Avatar
Toby-22
you can get the magnaflow xpipe to replace the hpipe. Theres a thread on it right now
Old Aug 29, 2009 | 08:23 AM
maXmood's Avatar
maXmood
Under Boost!
you mean the H-pipe is making the drone?
even tho i have HFC?
Old Aug 29, 2009 | 11:14 AM
Toby-22's Avatar
Toby-22
Test pipes or HFC you still removed the stock cats. Even still i heard Borlas tend to be raspy even with the stock cats. Read this my friend.
https://my350z.com/forum/intake-exha...ow-x-pipe.html
Old Aug 29, 2009 | 12:47 PM
maXmood's Avatar
maXmood
Under Boost!
i went through that^ already, but i thought things has changed with Borla exhaust since 1 year.
Old Aug 30, 2009 | 09:10 AM
SniperHunter's Avatar
SniperHunter
I have a very slight bit of drone at 1.5k-1.7k like you mention, but none anywhere else and I have a Borla TD with Ultimate Racing HFCs. But my Borla also does have the Magnaflow X-Pipe, which did quiet it a bit.
Old Aug 30, 2009 | 12:49 PM
maXmood's Avatar
maXmood
Under Boost!
i might end up buying that piece.
Old Aug 31, 2009 | 09:29 AM
maXmood's Avatar
maXmood
Under Boost!
i asked borla about this, and a block replied saying he stocks an item called "Venturi". it gets tac welded somewhere on the exhaust to change the rasp sound.
anyone knows about this? he's asking $24.99 without shipping.
Old Aug 31, 2009 | 10:30 AM
plumpzz's Avatar
plumpzz
a venturi tube is basically an X pipe.
Old Aug 31, 2009 | 10:34 AM
Jeff92se's Avatar
Jeff92se
No IMHO, it's nothing like that.
These little things are just welded into the pipe. Doesn't allow the exhaust to X over at all.
Old Aug 31, 2009 | 12:28 PM
maXmood's Avatar
maXmood
Under Boost!
how does it eliminate the drone?
Old Aug 31, 2009 | 12:50 PM
07sanmarino's Avatar
07sanmarino
I don't know about the Z but my last car had an unbelievably annoying drone, I ended up buying a Magnaflow 11216 muffler and having it welded in where the resonator was- reduced at least 90% of the drone. I haven't looked at underneath the Z so I don't know if this specific muffler would work but you could most likely find another that will, well worth it IMO- I know what it's like to drive long distances with drone. Btw, the muffler will elimate drone but not rasp, if you're looking to eliminate rasp a quality hi-flow cat would be best.
Old Aug 31, 2009 | 12:59 PM
maXmood's Avatar
maXmood
Under Boost!
i actually ment drone..
JjL
East Canada
Jun 12, 2019 03:04 AM
FromGtoZ
Sep 20, 2015 03:41 PM
PureR3d
Sep 10, 2015 06:23 PM
