Just got exhaust.. Is this normal?
Old Oct 5, 2009 | 05:30 AM
amendolaro's Avatar
amendolaro
Default Just got exhaust.. Is this normal?
I got the Bassani exhaust, and now is I'm driving and say I downshift, to 2nd and slow down and take off, if I let my rpm hit 1200, and I hit the gas, the car will bog/hesitate and shake sort of. What could cause this? Is this normal since more air flow? Please get back to me. Btw I have a 07
Old Oct 5, 2009 | 05:41 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
no. Go to the dealer ASAP
Old Oct 5, 2009 | 05:53 AM
amendolaro's Avatar
amendolaro
Will they void my warranty?
Old Oct 5, 2009 | 06:39 AM
AreYouAMac's Avatar
AreYouAMac
Put back your stock exhaust and see if this still happens. It can't be a pain in the *** to put on as the greddy evo-tt.
Old Oct 5, 2009 | 06:49 AM
2004Black350z
Exhaust Whore
only thing it will void is the exhaust part of the warranty. If they cant prove that ur aftermarket parts damaged ur vehicle then they cant deny service or a warranty claim. I honestly dont know what it is. Iv installed i think 13 exhaust now and never have run into the problem.
Old Oct 5, 2009 | 06:54 AM
Zazz93's Avatar
Zazz93
Second gear idle pull... I would imagine that would bog pretty bad. And just a touch of advice... DON'T bog the motor too much. It loads the bearings and leads to damaging them.
Sorry I can't check against my own right now but I'm pretty sure that would bog, shake and rattle.
Old Oct 5, 2009 | 07:12 AM
350z 6spd's Avatar
350z 6spd
It usually occurs on HR's with test pipes/HFCs although I can't remember if I have ever heard it happening with just a catback. When I had a stock exhaust with test pipes, I would get a bad hesitation at about 2500-3k rpm if I went WOT in any gear except first. There is plenty of info in the HR forum about the test pipe/HFC issue, maybe you can find something about a catback causing it
Old Oct 5, 2009 | 08:05 AM
freedonutss's Avatar
freedonutss
Any CELs? Try a full ECU reset to see if that will help any.
Old Oct 5, 2009 | 08:24 AM
Z-Dub's Avatar
Z-Dub
i know mine was bogging down really badly with test pipes. it should get better as time progresses, or reset the ecu. as long as there's no ses light, you should be ok
Old Oct 5, 2009 | 09:59 AM
VO...'s Avatar
VO...
Administrator
Not that the Z can't handle it, but doesn't 1200 rpm seem alittle low to be driving in gear at? If the OP is at that rpm in 2nd, perhaps he needs to be in 1st instead...
Old Oct 5, 2009 | 10:04 AM
fabcas311's Avatar
fabcas311
+1
Old Oct 5, 2009 | 11:08 AM
2004Black350z
Exhaust Whore
hahah wow i cant believe i missed that Vo. Yea +1000 if ur rpm is that low in any gear besides first ur car will want to stall out and it will shake and bog out. Thats what Vo told me bc i had to teach him how to drive a 6-speed
Old Oct 5, 2009 | 02:08 PM
amendolaro's Avatar
amendolaro
How do I reset ecu?
Old Oct 5, 2009 | 08:01 PM
350z 6spd's Avatar
350z 6spd
Either leave battery unplugged overnight or...
Never tried this on my HR but it worked on my DE. http://www.technosquareinc.com/350reset.htm
Old Oct 7, 2009 | 12:14 AM
SniperHunter's Avatar
SniperHunter
RPMs are too low. I'm sure your next reply will be "but it never used to do this before, I've always shifted/driven like this". That's because your new exhaust has changed the powerband a bit, and your torque curve has been altered, so you likely have less power in that RPM range now, but more of it past 1500RPMs, likely.
Old Oct 8, 2009 | 07:20 AM
scotts300's Avatar
scotts300
How do I reset ecu?
I would tell you, but I already helped you once and you told me to *** off: https://my350z.com/forum/7817521-post20.html
Old Oct 8, 2009 | 07:28 AM
TheOtherRob's Avatar
TheOtherRob
^ That is a good way to get banned.
Old Oct 8, 2009 | 09:22 AM
SexyRob's Avatar
SexyRob
this guy is dumb.
Old Oct 8, 2009 | 10:03 AM
Mikie13's Avatar
Mikie13
Yeah wishing kids would die and cancer upon us is pretty shitty. Lot of integrity that guy has.
Old Oct 8, 2009 | 01:27 PM
VO...'s Avatar
VO...
Administrator
Just read the post in the link above...
