Advanced Resonance Tuning (ART pipes)
Old 07-08-2011, 10:30 PM
  #601
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Hydrazine's Avatar
Contact us for pick ups. And yes, we always have discounts for US Military.
Thank you for your service!
Old 07-11-2011, 09:25 PM
  #602
scotts300
scotts300's Avatar
Have you had a rev-up car (05' anniversary) with a supercharger set-up with the ART pipes yet? If not, I know someone who may be interested and was curious if a discount would apply! Cheers!
Old 07-11-2011, 09:53 PM
  #603
Hydrazine
Hydrazine's Avatar
Not yet. What would it be compared against?
If compared against cats, the cats will win that comparison because superchargers clearly need some backpressure for optimum performance.
NA and turbo engines however do not.
Old 07-11-2011, 10:13 PM
  #604
scotts300
scotts300's Avatar
Fair enough. That car has wrecked a set of high-flow cats due to recent, heavy, track usage, so the owner and I were talking about getting something with some higher flow. I don't know if they were a metal or ceramic core though. What would you recommend?
Old 07-12-2011, 06:43 AM
  #605
Hydrazine
Hydrazine's Avatar
Check this out.
+30 HP by installing the XYZ HFC on a vortec Z: https://my350z.com/forum/forced-indu...g-results.html
And the XYZ HFC will be able to endure more track punishment because the HFC is moved away from the engine where exhaust gasses will cool down by about 500'F by the time it reaches the converter.
Old 07-12-2011, 07:49 PM
  #606
ChriZTT
ChriZTT's Avatar
^ very interesting.
Old 07-19-2011, 12:33 PM
  #607
VQpoweredZ
VQpoweredZ's Avatar
I just had these installed on my HKS True Dual and they sound nice. There is a small rattle when I go over bigger bumps, nothing too big at all really, I'm just wondering if this is common.
Old 07-19-2011, 03:18 PM
  #608
67ZNISMO
67ZNISMO's Avatar
Did you shave the screw?
Old 07-19-2011, 03:46 PM
  #609
VQpoweredZ
VQpoweredZ's Avatar
^^ Thanks man. I was lazy and didn't fully read that in the previous pages. That makes a ton of sense. Will have to do that thanks.
Old 07-19-2011, 10:22 PM
  #610
Hydrazine
Hydrazine's Avatar
Yes.
Everyone be sure to trim that stud hanging down when installing the ART pipes. A cutoff wheel on a air die grinder takes about 2 seconds and its gone.
Old 07-21-2011, 10:13 AM
  #611
VQpoweredZ
VQpoweredZ's Avatar
Just to be sure... this is only the drivers side bolt that needs to be shaved, not the passenger side correct?
Old 07-21-2011, 10:21 AM
  #612
e30cabrio
e30cabrio's Avatar
Received 2,596 Likes on 2,053 Posts
On my car yes.
Old 07-21-2011, 11:08 AM
  #613
Hydrazine
Hydrazine's Avatar
Only on the driver side.
Its described in the installation note sheet.
Old 09-29-2011, 10:29 PM
  #614
PeterSellers
PeterSellers's Avatar
Just got a set installed on my 08. Power is great, I'm very happy with them.
One problem I'm having though is a rattle on thr drivers side. It sounds like the pipe is hitting the heat shield, but I'm not sure exactly. The rattle is significantly louder when the engine is cold, though it never goes away completely. It also only occurs at around 1.5k-2k rpms, all other ranges are fine. I did trim the bolt as it described in the instructions.
After installing and turning the car on for the first time I noticed that there seemed to be excess vibration with the drivers side pipe. I'm wondering if the pipe is slightly out of alignment, so I'm going to loosen and retighten the bolts connecting to the y-pipe and hope that fixes it. I may also take off the heat shield. Is it bad to remove the heat shield? Anything else that could be causing the rattle?
I'm also running the stock catback, by the way.
Old 09-30-2011, 12:31 AM
  #615
Hydrazine
Hydrazine's Avatar
The fiberglass in them needs ~1500 miles to break in. It may simply be rasp that you are hearing. There will be some rasp when they are connected to the stock exhaust.
Give it some time (1500 miles) and let me know what you find.
Old 10-02-2011, 04:07 PM
  #616
Z_enthusiast
Z_enthusiast's Avatar
Hydra, i just bought some V1 art pipes and my question is this... Having a 2 step/no lift shift my car has big loud back fires. after blowing stock cats i went with res tp's but now to these. should i be worried about blowing the guts out of the v1's? Thanks, Craig
Old 10-02-2011, 06:00 PM
  #617
350Z_Al
350Z_Al's Avatar
Could the rasp sound like a little metal ball rattling inside one of the hemholtz chambers under light throttle from 1800-2500rpm?
Old 10-02-2011, 06:11 PM
  #618
Z_enthusiast
that sounds like the typical test pipe hiss/rattle
Old 10-02-2011, 08:06 PM
  #619
Rubidium
Rubidium's Avatar
I just bought a set of these as a birthday gift to myself!
Old 10-03-2011, 07:11 AM
  #620
Hydrazine
Hydrazine's Avatar
No. There is nothing in them to blow out. ART pipes are blow out proof.
Quick Reply: Advanced Resonance Tuning (ART pipes)
