megan y-pipe and nismo y-pipe same?
Old Feb 14, 2010 | 10:22 PM
medinafx's Avatar
medinafx
Default megan y-pipe and nismo y-pipe same?
is the megan and nismo the same besides being different brands. currently i have berk test pipes with a stillen ypipe and im getting tired of the drone at low rpm will the megan or nismo help with the drone?
Old Feb 15, 2010 | 01:46 AM
ssgohan434's Avatar
ssgohan434
cliffs:
they're not the same. nismo is much better quality/welding.
but they both are flawed.
megan sucks (cheap craftsmasship) & the nismo y-pipe is known for breaking testpipes/and after market high flow cats.
Old Feb 15, 2010 | 08:34 AM
rawley_12003's Avatar
rawley_12003
i have the kinetix hfc with the megan y-pipe and have had them on for more than 6 months and no issues make sure you replace all the gaskets though if it leaks you car will sound like its farting lol...
Old Feb 15, 2010 | 08:39 AM
03LeMans350zed's Avatar
03LeMans350zed
i had a megan turbo outlet and dump pipe on my S14 with SR20det with not issues.
Old Feb 15, 2010 | 08:49 AM
TheFarmer's Avatar
TheFarmer
Nismo is good stuff.
Old Feb 15, 2010 | 08:55 AM
03LeMans350zed
agreed.
Old Feb 15, 2010 | 06:13 PM
medinafx's Avatar
medinafx
very true but i cant find a nismo ypipe by itself or does anyone know were to find one and megain is the closest thing to it im tired of my stillen
Old Feb 15, 2010 | 07:36 PM
ssgohan434's Avatar
ssgohan434
how do you know if swapping Y's will help elim. the drone?.... you may be dissapointed. see what other people with the same exhaust are using and how it sounds/their opinions.
Old Feb 15, 2010 | 10:23 PM
medinafx's Avatar
medinafx
any one how to reduce drone without taking the test pipes off or will ypipes with resonators help?
Old Feb 15, 2010 | 11:47 PM
Jairen's Avatar
Jairen
Your best option would be the Motordyne XYZ with resonator.
Old Feb 15, 2010 | 11:59 PM
jerseystyle's Avatar
jerseystyle
+1
Old Feb 21, 2010 | 08:42 AM
chewy08753's Avatar
chewy08753
Has any one welded in hfcs to a y pipe? I have magnaflow weld in hfcs and was going to cut my test pipes and weld them in, but i also have an extra nismo y pipe laying around was going to cut the flex piece out and try welding them in there or see if i can sandwich them in after the flex, so that i can swap back if i don't like the way it sounds or if power sinks any input would be appreciated Thanks
Stevo Z
Oct 3, 2015 09:14 PM
nanotech
Oct 2, 2015 05:02 AM
