test pipes-engine replacement warranty
Old Aug 8, 2010 | 01:13 PM
Z-33's Avatar
Z-33
Default test pipes-engine replacement warranty
hey guys so i have a 06 and i just got the short block replaced like a month ago due to oil consumption. now the car is burning again, but i have installed testpipes and intake. do you think the dealership will try to blame the issue on these mods even though the engine has already been classified as a oil burner??? let me know guys, cuz im going to be bringing it into the dealership as soon as i get a chance.
Old Aug 8, 2010 | 02:05 PM
Yes.
Old Aug 8, 2010 | 02:06 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Always go back to stock before bringing warranty work to the dealer.
Old Aug 8, 2010 | 02:23 PM
terrasmak's Avatar
Depends on your dealer
Old Aug 8, 2010 | 03:08 PM
350ZTheStandard's Avatar
350ZTheStandard
This should be a no brainer.
Old Aug 8, 2010 | 11:34 PM
Z-33's Avatar
Z-33
so lets say i go in with my mods, and they say sorry we cant do the work bc u have the mods. will they void the warranty, or can i go to another delership. the thing is i just got the test pipes installed and it cost me a 100 bux to get them put on i dont wanna pay another 200 to get them off and than put back on.
Old Aug 9, 2010 | 12:31 AM
sdZ33's Avatar
sdZ33
By law, they have to prove that the mods actually caused the problem... The dealership can be cool and just do the work, or they can deny it and tell you that the TP's caused the oil burning... Either way, I would play it on the safe side and just remove them... It might cost you a couple of hundred bucks, but at least you'll get a new engine and not run the risk of them telling you that they won't change it and your stuck with a burner...
As far as them voiding the warranty, from what the service writer told me at my dealership, is that if they have proof that the mod caused the problem, then only the part will be voided...(I'm not too sure how that works, but that's what I was told)...
I.E: Let's say you install coilovers and a suspension part that would normally be covered under warranty breaks, the warranty would be voided for that part...(Like I said, that was how the service writer at my dealership explained it to me)... GL
Old Aug 9, 2010 | 01:48 AM
dmroberson's Avatar
dmroberson
they will try to blame it on your aftermarket parts, but like sdZ33 said, they have to prove it. Lookup Magnusson-Moss Warranty Act.
As stated, go ahead and take your aftermarket stuff off before you go in. It'll make things much easier on you.
My dealership tried to blame the oil consumption on my aftermarket stuff too. So I called the BBB, when I started getting the run around, and I also kept everything off while they tested the 2nd engine.
Old Aug 9, 2010 | 09:06 AM
Entaille's Avatar
Entaille
sounds like a good opportunity to invest in the tools to do it yourself
Old Aug 10, 2010 | 02:05 AM
sdZ33's Avatar
sdZ33
+1... Use those $200 on some tools and just do it yourself...
Old Aug 10, 2010 | 05:20 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
if you have to ask the question, you already know the answer
OP is in Canada, there is no MM Act to refer to, I am sure they have their own laws, and the dealer has their own policies.
Old Aug 10, 2010 | 06:11 AM
RandomHer0's Avatar
RandomHer0
My buddy has brought his APS TT G into the dealer for work, never had an issue. Depends on the dealer.
Im in Canada.
Old Aug 10, 2010 | 06:53 AM
Gingervitis526's Avatar
Gingervitis526
Test pipes are an easy install, definitely invest that $200 into tools. It will save you a ton of money in the long run.
Old Aug 10, 2010 | 10:36 AM
POWUH's Avatar
POWUH
no . my engine was replaced and i had the following , aam test pipes , injen exhaust , pulleys , jwt and they did not mention a single thing about it.
Old Aug 10, 2010 | 07:31 PM
Z-33's Avatar
Z-33
hey guys so i went into the dealership today with my test pipes and intake still on the car. and they didnt say anything, and are still going to replace the engine.
issyz
Jul 2, 2017 03:04 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
350z82
Oct 1, 2015 06:25 PM
