New test pipes & y-pipe - cheap!!
Old Dec 4, 2010 | 04:57 PM
BakaN20's Avatar
BakaN20
Originally Posted by davidv
Would appreciate if you would inspect the pipes after 20,000 miles. Reliability is key.
I'll get back to you in probably 10 years then, lol. The first 2 years I owned my Z, I put 33k on it, the past 2 years, I put 1k on it, since I bought a daily driver, lol. Thats 1 reason why I went with a cheaper y-pipe, since I only drive the car every so often, longevity wasn't an issue. Even if it breaks within 3,000 miles, that would probably be 3-4 years from now for me, but I guess thats not the case for everyone.
Thats why I tried to take pictures of the welds and the thickness of the pipe, hopefully it helps people.
Old Dec 4, 2010 | 04:59 PM
Max626's Avatar
Max626
BakaN20 why do you want to change your nismo pipe for a megan one?
Old Dec 4, 2010 | 06:37 PM
BakaN20's Avatar
BakaN20
I think my nismo is leaking, I had test pipes put on, so I am going to replace the y-pipe and see if that fixes the problem. The megan was modeled after the hr y-pipe also, so maybe it will give better performance, lol.
Old Jan 8, 2011 | 11:25 AM
luckyboy06's Avatar
luckyboy06
Default Nismo Ypipe culprit.
Hello Z cruzn,
My stock passenger side Cat was cracked after one year with a used Nismo exhaust system.
It was setting off the check engine light.
Luckily the dealership replaced both cats under warranty. Whew!
The flex tubing began to unravel and I picked up a plastic grocery bag.
It melted unto the Ypipe and sent toxic fumes. The flex was frayed and the plastic bits were imbeded beyond removal.
I replaced the pipe with the stock HR Ypipe.
The exhaust lost it's sound and I started looking for another Ypipe.
I just purchased an aftermarket Ypipe from Top Speed Auto Accessories, Inc.
I am going to install it this week.
Please inform us if your test pipes or high flow cats crack.
I will try to post pictures this week.
Thank you for your time,
Lboy06.
Old Jan 16, 2011 | 10:04 AM
rich2342's Avatar
rich2342
Originally Posted by luckyboy06
Hello Z cruzn,
Lboy06.
Curious if you will notice loss of low end torque with your new y-pipe. Post some feedback if you can.
Old Feb 7, 2011 | 09:00 AM
bschlatt's Avatar
bschlatt
Originally Posted by Z CRUZN
davidv - I knew I read it somewhere here several times...didn't remember that it was you! (At least I gave the "unknown" writer credit in my post - ha!). As for the 20k mile statement, I'll be happy if the tp's last that long, for sure!!! After 2k miles, still look like new........BTW, I spent $166 total (shipped) on the M2 tp's & y-pipe from m-motorsports, a forum vendor here (around $76 on the tp's & $90 on the y-pipe).
Searched for this vendor in the directory. Not there.
Old Feb 8, 2011 | 11:59 AM
Patsfan83's Avatar
Patsfan83
CMon you gotta give us some sound clips~!!!!!!!
Old Jul 9, 2011 | 01:54 AM
Eva G's Avatar
Eva G
When I had a Megan (DE version Y-pipe) with TurboXS TP/Nismo mid-back exhaust, my TP didn't start to crack until about a year to a year and a half. But when I replaced the Megan for a Nismo Y-Pipe (after Tig-welded it to seal it), my TP's cracked after 4-5 months....
Old Aug 12, 2011 | 05:28 PM
alnfong's Avatar
alnfong
Question
Would the "Check engine Light" comes on after I installed the Test Pipe??
Old Aug 12, 2011 | 07:49 PM
Bmurray350z's Avatar
Bmurray350z
Depends if the test pipes come with the o2 sensor fix.. my Berk Technology test pipes came with the sensor fix and they've been on my car for over 6 months and no CEL yet. knock on wood. and even with the o2 sensor fix, it only works about 95% of the time they say.
Old Aug 12, 2011 | 08:43 PM
DaveJackson's Avatar
DaveJackson
Master
What year is your car?
Old Aug 13, 2011 | 09:15 PM
alnfong's Avatar
alnfong
Thank you for the reply guys!!!And my Z is 2004!!
Old Aug 13, 2011 | 09:30 PM
DaveJackson
Master
An '03 almost certainly won't activate a CEL. An '04 might, but there is, maybe a25% chance that it won't.
Try those extension things.
Old Aug 13, 2011 | 09:45 PM
alnfong's Avatar
alnfong
cool...I'm still waiting for my Y-pipe to come,already got my Berk test pipe!!Because I'm currently running with Nismo cat-back exhaust,and heard a lot of issues with the Nismo Y-pipe.So I wanna change both @ the same time!! Anyway,what extension thing r u talking about?? R they expensive?And where can I get them from??Thanks again!!
Old Aug 13, 2011 | 10:24 PM
350Zdj's Avatar
350Zdj
Good review, OP!
Just wanted to share... My Topspeed res. TP's have completed about 18k miles and still in top condition despite getting scrapped over humps many times. I've installed the Stillen engine damper about a year ago to keep the pipes from flexing too much. So i guess some Ebay stuff aren't bad at all. In fact, too underestimated IMO.
Old Aug 12, 2013 | 03:59 PM
Z CRUZN's Avatar
Z CRUZN
Almost 3 years since installing the cheap test pipes & y-pipe I opened this thread about.....driver side test pipe cracked yesterday. These $70 test pipes lasted as long if not longer than the previous sets of more expensive pipes I've used. This time I'm using a flex-pipe set of Top Speed Pro 1 test pipes. Just ordered them today for $101 shipped & should have then on by Fri. night. Will update......
Old Sep 21, 2015 | 01:21 PM
Nismogonza27's Avatar
Nismogonza27
Default Hi
May be old news for some or not that big a deal for some, but I thought I'd share a bit about a purchase & install I made. As posted on another section, I ordered a set of M2 test pipes & an M2 y-pipe from Marinelli Motorsports (vendor here). After going thru several average priced hi-flos & test pipes, I decided to go a little less expensive this time & see what happens. I don't know if I should post the prices here since we have to PM m-motorsports for the prices, but I will say the test pipes & y-pipe were under $200 total...shipping included - quite a bit less than what I have paid in the past!!
Anyway, I installed the pipes tonight - fit was perfect. I ran the test pipes & the y-pipe into my Nismo exhaust I've run for the past 6+ years. Although this M2 y-pipe is almost an exact match to the Nismo y-pipe, it does sit a bit higher at the collector end thereby not pulling down on the cat pipes like my original Nismo y-pipe did & cracked multiple sets of HFC's. Of course, the rasp is there while putting your foot into it for those curious. With the Crawford headers into straight pipes into a Nismo exhaust, the sound is pretty raw & wild at WOT- a sound that I've been used to for years so no biggie. As before, at idle it is pretty quiet.
Anyway, just wanted to inform a few people if you're looking for an inexpensive setup. Time will tell how these pieces perform as per cracking, etc. I'll update if need be. Until then, I'm quite happy with the fit during install, the welds, the collector on the y-pipe (a little sloppier inside than the Nismo y-pipe, about the same that I've seen on several others I've run and/or helped install in the past). Here's a few shots of the packaging, the welds, the inside of the collector and the installed look. Hope this helps any of you. Oh, the inside diameter of the test pipes are 2.25" & the collector end of the y-pipe is 3.00". They also came with all hardware & gaskets.
Hey man I know this is a old post but what website did you get the pipes from or what ? I have 08 Nismo , thanks
Uriyo_
Sep 8, 2021 08:46 AM
issyz
Jul 2, 2017 03:04 PM
Justin100
Nov 29, 2015 03:58 PM
codek
Sep 28, 2015 03:03 AM
