High Flow Cats - Crawford or Random Technology?
Old Nov 30, 2003 | 06:01 PM
  #41
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Originally posted by Z1 Performance
jason - you can see what I ean by looking at jeff's - his crossed in the right spots...now that is weird!
MINE DOO TOO!!!!
ITS AN ILLUSION!!!!
LOOK AGAIN!!!
The BLUE and DARK BLUE cross at about 5750
and the RED and DARK RED croass at about 5750!
the new run is just moved up in HP and TQ...
We were all looking at it as if the RED and BLUE were one run and DARK RED and DARK BLUE were a differnet.. when it was RED and RED and BLUE and BLUE.. hehe
Old Nov 30, 2003 | 06:14 PM
  #42
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Yeah but look at where his cross - your corss over points are like 5700 - Jeff's are around 5200 where they should be..maybe your car is just possesed
Old Nov 30, 2003 | 06:20 PM
  #43
Jason@Performance
Performance Nissan
then my car is possesed!
because one of the runs (the lower one) was done rite after jeffs on the same dyno as soon as they pulled his car off and put mine on!
so what does this mean for my car? is it making more power up top for some odd reason?
Old Nov 30, 2003 | 06:22 PM
  #44
Z1 Performance
Former Sponsor
just means its weird
not sure - what wheels are you running?
Old Nov 30, 2003 | 06:23 PM
  #45
Jason@Performance
Performance Nissan
stock wheels...
rear tires for the dyno pulls were on stock 18's with Potenza S03's...
I think they might be slightly taller then the stock tires...
but they are 245/45/18's...
could that be it?
Old Nov 30, 2003 | 06:28 PM
  #46
Jason@Performance
Performance Nissan
Originally posted by Jason@Performance
stock wheels...
could that be it?
that shouldnt be it.. because my 245/45/18's are the same diamater as jeffs 275/40/18's...
I have a possesed car!
that explains alot actually..
Old Nov 30, 2003 | 06:31 PM
  #47
Z1 Performance
Former Sponsor
Cool!!!!! I have owned a couple of those over the years (my Suabru comes immediately to mind)....take good care of her!
Old Nov 30, 2003 | 06:39 PM
  #48
Jason@Performance
Performance Nissan
Its soo weird though that the Torque is way over 250 but it says its only 230something.
:totally lost:
Old Nov 30, 2003 | 06:52 PM
  #49
Z1 Performance
Former Sponsor
gt back to that dyno this week and tell them to recalibrate before you get there...or maybe jsut go over the result wth the owner or the guy who usually supervises the runs....hopefully he can shed some light!
I'll be going to our local dyno shop this week for the high flow cats and Y pipe, once the gaskets I need come in Wed
Last dyno I did on the one we usually use was 268 hp and 263 torque (intake, cat back exhaust (non dual) and crank pulley.....is 280 possible without cams, headers, plenum or ecu work? Stay tuned .
I definately want to do the plenum, just don't want what is currently out there.....
  #50
PhoenixINX's Avatar
PhoenixINX
Guys...
The reason the cross point is off is because they have unscaled your chart.
Each side, both hp and ft-lbs has to be indentical.
Each one is scaled independantly.
The different tires sizes?? Dyno's for 4th gear and 5th are yielding NEAR IDENTICAL results. Such a minute difference in tire size, in turn FD ratio won't make any difference.
Old Nov 30, 2003 | 07:02 PM
  #51
Jason@Performance
Performance Nissan
Originally posted by The Individual
Guys...
that is what my next guess was, i just thought about it while i was emptying the dish washer...
damn, im not making over 250ftlb's tq
Old Nov 30, 2003 | 07:14 PM
  #52
Jason@Performance
Performance Nissan
On my ODD dyno graph, I think the RPM's are accurate but the HP and TQ Graph is wrong... wack
Old Nov 30, 2003 | 07:28 PM
  #53
jeff's Avatar
jeff
I think the Individual is correct. If you read the correct scale HP(left)/TQ(right) for the curve you are looking at, the numbers are correct. Your MAX HP, the light blue line, is right about 248 @ 6300, and your MAX TQ, the dark blue line, is around 240 @ 4600.
Adam, let us know about those magnaflow cats.
Jeff
Old Nov 30, 2003 | 07:30 PM
  #54
Jason@Performance
Performance Nissan
Yeah, the HP / TQ scale is off...
but the RPM's are still accurate it looks like...
now the question is are my HP/TQ numbers really crossing at 5750 or 5250...
Old Nov 30, 2003 | 09:04 PM
  #55
D'oh's Avatar
D'oh
Jason,
You are still missing the point.
Your original chart is fine, it's just that the torque and HP curves are using DIFFERENT scales (neither is WRONG, they are just DIFFERENT). The HP and Troque curves will only cross @ 5250 when they are plotted on the SAME scale.
On your original chart, the max numbers shown on the header match the curve as long as you look at the correct scale.
When you plotted your dyno the second time with Jeff's, the scales ended up the same, and therefore everything crossed at the correct spot.
There's no need to get anything calibrated (at least not based solely on your original chart).
-D'oh!
Old Nov 30, 2003 | 09:09 PM
  #56
Jason@Performance
Performance Nissan
I know nothing needs to be calibrated with the dyno and the scale of the graph is just off.
im going back there friday , ill have him re-print this sheet for me cuz its damn anoying to look at now...
(_8^(l)
Old Dec 1, 2003 | 06:12 AM
  #57
ZPirate's Avatar
ZPirate
Just returned from Thanksgiving. Thanks for the info, although I am still not sure which way to go with the cats. I guess RT cats may be better from an emissions standpoint since they have been tested and certified.
Old Dec 1, 2003 | 02:13 PM
  #58
zzzya's Avatar
zzzya
So have the Crawford cats, plus they will pass visual inspection!!
Old Dec 1, 2003 | 02:20 PM
  #59
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
Originally posted by zzzya
the Crawford cats will pass visual inspection!!
So will the RT's..... just not in Calif. Although you still can't see them.
Old Dec 1, 2003 | 02:21 PM
  #60
Jason@Performance
Performance Nissan
They come with a CARB Certificate too
