View Poll Results: Who here has had problems with their MAF sensors due to an oiled air filter (ie. K&N)
I have!
24.00%
Not me!
19
76.00%
Voters: 25. You may not vote on this poll
How many poeple with aftermarket oil filters have problems with the MAF sensor?
Old Nov 26, 2003 | 04:00 AM
jmombour's Avatar
jmombour
Default How many poeple with aftermarket oiled air filters have problems with the MAF sensor?
I was reading up on people with aftermarket oiled air filters such as K&N drop in filters who have had problems with their MAF sensors. I haven't had any problems with mine in my Z or any of my other Nissan vehicles (Pathfinder & Maxima), but I am curious to see if anyone else has had problems with theirs. I have also cleaned and re-oiled my K&Ns without any problems. Am I just lucky?
Old Nov 26, 2003 | 07:25 AM
jmombour's Avatar
jmombour
I should also ask if you don't have problems with it, what sort of preventative maintenance, if any, do you do to remain problem free?
Old Nov 26, 2003 | 07:37 AM
mrZeee's Avatar
mrZeee
no prob in four other vehicles...popped one in my Z seems to be good with about 1k on the filter so far..I saw a spike in MPG ,23 mpg, (which is why I buy them , not really for HP) but went back to normal after a day or two, 21/22 mpg...
Old Nov 26, 2003 | 08:06 AM
jckolnturn's Avatar
jckolnturn
The oilled air filter is the #1 reason i don't get an aftermarket intake. Check out the oil build up in the tube after several thousand miles, it can't be good for the MAF.
Old Nov 26, 2003 | 08:07 AM
mydogscool's Avatar
mydogscool
The secret is not to over oil the filter after cleaning. Spray oil on lightly, let sit a while, shake any loose oil off. If none comes, repeat, until just a litlle oil shakes out. Shake out all remnants of loose oil. Install filter.
Old Nov 26, 2003 | 02:46 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
exactly as posted above.
We have used K&N's on cars with notoriously sensitive MAF's (Subaru) and have never had an issue. 9 times out of 10 in my experience, the problem is people overoiling (ie oiling a filter when it comes out the box -I see that all the time)
Old Nov 26, 2003 | 08:45 PM
Z8M's Avatar
Z8M
That is so true. I had my Nismo CAI for about 1500 miles, checked the MAF tube and found oil build up. Over time I think this will eventually foul up the sensor. Nismo uses K&N I believe. I got scared and put the stock airbox back in.
Old Nov 26, 2003 | 09:35 PM
Daniel G's Avatar
Daniel G
I had a 'holley power shot' filter for my SS camaro. The 'power shot' filter is basically the same thing as K&N..supposidly flowed better than K&N because of better pleates. Anyway, the MAF sits a lot closer to the filter on the SS than it does on this car and I had no problems, but I know some people did...too much oiling. What I did was after oiling the filter..I used my shop vac to suck up the excess.
liqalu04
Jan 2, 2022 12:58 PM
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
