The B-pipe is noticeable with larger diameter, that along should give you more HP gain. SCC didn't change the B-pipe, all they did was changing the muffler...which was not design for our Z anyway
Originally posted by raceboy OK, but what were the dyno result?? JIC lost HP, interested to see how this faired.
....JIC didn't (doesn't) acutally HAVE an exhaust system for the 350Z yet. THey simply tried to improvise one on the spot (within the few hours they had available from SCC). No testing/R&D or anything, just using two Porshce mufflers welded together and a pipe following the stock path. Now that the car is out I am sure they'll be able to do testing and R&D to come up with a good design, but like the article said, there probably isn't a massive ammount of HP to be gained there...This system on the other hand, I am sure will yield gains. Since Fujitsubo was building the exhaust for Nissan, you know they had test 350Zs available, so they were able to improve on Nissan's design....BTW: Looks very nice...
