08 350z w/invidia gemini + art pipes. or tdx v2.
Old May 15, 2011 | 12:20 PM
chaz1288's Avatar
chaz1288
Default 08 350z w/invidia gemini + art pipes. or tdx v2.
Has anyone paired up the gemini and art pipes. I can get both for the price of the motordyne tdx v2 by itself. I was pretty set on the tdx v2 but for the price I am leaning towards the more bang for my buck.. I had invidia n1 on my eclipse and it was excellent. is there that big of a difference between the motordyne tdx v2 and invidia gemini. also will they bolt up? any input. thanks
Old May 16, 2011 | 03:30 PM
Nismo1534's Avatar
Nismo1534
Unless you are going to boost, every cat-back is the same, as far as power is concerned. So long as you are replacing the restrictive OEM cats, either exhaust should yield the same power gains and they will both bolt up fine. Now, if you were going to boost, or run some aggressive cams, then the Motordyne would be the way to go.
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
codek
Sep 28, 2015 03:03 AM
