Cheap Mods for Loud Exhaust?
I really like the looks of my stock exhaust, and its in great shape with low miles, just looking for a louder tone - without spending 1200 on the Nismo! Yes Im cheap.
Has anyone experimented with simply welding in a Borla muffler or similar and keeping the rest of the setup tips etc. for a cheap upgrade?
Are there any Baffles or anything I can remove to make the stock exhaust louder?
With an aftermarket exhaust you are basically paying a TON of money just for stainless steel or what not which is a waste in IMHO
Im thinking something like this, I mocked this up with a Borla XR-1 - not sure if they have a model with the right size piping, but this is if they did - simply weld either side and then weld on the two hangers and your done - 130.00 muffler..
The reason I want to do this is because all of these aftermarket exhausts except probably the NISMO seem to give the car that "ricer" look, and I don't want that - or also they cut the cars ground clearance big time on angles, speed bumps, etc.
Although, as I said if there are any baffles or even the cats to remove that change the sound significantly I would do that too.
If people do this to other vehicles what is stopping you from doing it?
But seriously, by the time you get done searching for and buying the right style universal muffler, paying to have this all fitted and welded, you could just buy an exhaust from the marketplace..........
About $500 will get you something decent. You'll probably spend $300 on your Frankenstein set up anyway.
I have no problem cutting out the cats there is no emissions here - or usually I just hollow them out with a hammer and punch, that has worked in the past nicely for my trucks. How does that sound on a 350?
This one has a single inlet, dual outlet but the stock muffler is not set up the same way. The stock muffler has an inlet and one of the outlets on the same side.
Edit: read the page description again and not sure if they are universal. I'll have to look around more for one with universal inlets and outlets..
Go to youtube and listen for yourself. I have heard a couple Z's and G's with stock exhaust and test pipes or HFC's and I do not like the sound. Raspy is the only word I can think of. Check out the youtube video of a 350Z with the resonator on the mid pipe cut out. This might be the right mod for YOU. Search for "350z resonator delete".
I believe all of the inlets/outlets are advertised as universal so you can do what you want with them if I read the description right. But I may be wrong, I know what your saying, but just trying to show an example - there is probably a muffler for sale out there for 100 bucks that will work and I have a mig welder...
The other exhausts that are cheaper seem to be big cans and they all look too ricer or they cut down on clearance and will scrape everywhere.
So my goal was to keep the stock tips both of them if I did this, but that is why I was posting to see if anyone had tried it - Im not saying its possible. It seems like right now the options would be 1. Text Pipes 2. Drill Holes or 3. Cough up 1200 dollars for a nismo, or 4. put a cheap big can on the end which I dont really want to do, but for the money I might...
I really don't like that sound either.
Dont cheap out br0
I would replace the stock exhaust with a Topspeed N1 or the Amuse R1 Titan for teh loundness=sexy sound, but thats just me...
Topspeed N1:
http://www.youtube.com/watch?v=X49F5XHNg3k
Amuse r1 Titan
http://www.youtube.com/watch?v=QKr4yq_2rsg
Topspeed N1:
Amuse r1 Titan
I have the 3" version of the Top Speed N1 and it is VERY loud and has a very deep tone. Found it for $150 last year in the Marketplace. But you need to take some extra strength Tylenol before and after a long drive.
