pop charger
Old Dec 24, 2003 | 07:13 AM
ZedZed's Avatar
ZedZed
Oh yesssss! The sound is amazing! It's a combination of a roar and a hissssssss.
The jury is still out on the ECU negating mods.
Old Dec 24, 2003 | 12:31 PM
lowrider's Avatar
lowrider
Well, I bought a POPcharger this morning. I thought I was through messing with my intake. Currently have K&N, "Z" Tube, and a Crawford. I'll let you guys know how it performs on my "G".
Lou
Old Dec 24, 2003 | 07:04 PM
mzack's Avatar
mzack
I installed my JWT last week. Only took 1.5 hours. took it out for a spin. Instant sound diference and I am having trouble keeping the tires from breaking loose (thats good). I cannot believe that there would be a decrease in HP. I think the 11 HP gain is correct. At least I can tell an imediate difference. Get one now. Forget the rest, go with the best. I did my research on this one.
Now its time to get the exhaust.
Old Dec 24, 2003 | 07:41 PM
FLY BY Z's Avatar
FLY BY Z
I don't know what took you 1.5 (beer and contemplation?) mine took about .5 but I had taken the silencer out (which the heat shield screws to) previously so it took me about 3 hours to custom fab (trial and error) a metal bracket to secure the front of the heat shield at midnight from two random pieces of metal found around the garage with some pliers, a vice, a hammer, and a hacksaw. A beating I tell ya! But WORTH it, you are RIGHT. I do like this intake. Cheap and highly effective.
Old Dec 25, 2003 | 04:51 PM
uro279's Avatar
uro279
What is a "Z-tube"?
thanx
Old Dec 25, 2003 | 05:45 PM
FLY BY Z's Avatar
FLY BY Z
Originally posted by uro279
What is a "Z-tube"?
thanx
The intake tube on the Z. G35s don't have the same tube so they like to put ours on because they envy us and want to be us and they want our power.
Old Dec 25, 2003 | 06:07 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
Why not buy the Injen CAI and use it as a short Ram air intake?
Old Dec 25, 2003 | 06:09 PM
lowrider's Avatar
lowrider
Mr. Z
Well, 1 out of 3 aint bad. We do not envy you, we do not want to be you, we do not want your power. What we want is more power, just like you do. Using the "Z" tube is one of the good things we do.
The Ingen tube is not as good as the "Z" tube because it absorbs more hot air than the plastic in the "Z" tube. Also, I believe the Ingen is smaller in diameter. The Ingen is better looking, but the "Z" tube works better.
Lou
Old Dec 25, 2003 | 06:17 PM
NY 350Z's Avatar
NY 350Z
i ordered my pop charger just a couple hours ago. since its xmas..and the weekeds commin up,im predicting itll come wed. or so.but ill tell you guys what...i WILL take pics,and ill try my hardest to get a sound clip.i promise. hopefully itll make decisions more easier to make.
Old Dec 25, 2003 | 06:43 PM
FLY BY Z's Avatar
FLY BY Z
Originally posted by lowrider
Mr. Z
Oh come on. Be honest!
Old Dec 30, 2003 | 05:32 PM
Morphiend's Avatar
Morphiend
Can any one tell me, does the Pop Charger void warranty? I know the CAI could possibly, is it the same as the CAI or a solid yes or no?
Old Dec 30, 2003 | 07:09 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
Sorry no solid yes or not, but it depends on your dealer. Some are cool with modifications others will try to deny any claim if you've modded your car. But again, there is a law that the dealer has to prove that the aftermarket part caused the failure.
Old Dec 31, 2003 | 10:29 AM
Morphiend's Avatar
Morphiend
So, if some thing did by chance happen to my engine, I could take it to performance nissan, and it would most likely be no problem.
Do these kind of things have any real history of making problems for the engine?
Old Dec 31, 2003 | 11:00 AM
uro279's Avatar
uro279
Best to call Performance Nissan directly and speak with either Jeff, Jason, or Jenny for the answers to your question.
Old Jan 2, 2004 | 04:18 AM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
I haven't heard of any consistant problems, just be careful with the MAF sensor when you install.
Old Jan 2, 2004 | 05:07 AM
ZedZed's Avatar
ZedZed
Go easy on the oil, if you decide to oil the filter itself. You don't need to oil it, but to trap fine dust and dirt, you should oil it.
People are frying their MAF sensors when they oil up the filter too much, and oil gets sucked into the intake and coats the MAF with oil.
I oiled up the filter, stuffed the inside with paper towels, and let it sit for a couple hours.
Old Jan 2, 2004 | 05:21 AM
TommyZ's Avatar
TommyZ
My popcharger should be arriving any day now. I haven't heard of this.....what kind of oil are you guys using to coat the filter?
Old Jan 2, 2004 | 06:33 AM
  #38
scottycoyote's Avatar
scottycoyote
how difficult is it to put on.....do you have to cut or alter anything? If i wanted to take it off when my car goes to the dealer will all the original stuff go back on?
Old Jan 2, 2004 | 11:50 AM
  #39
MyZ4U2C's Avatar
MyZ4U2C
Just use something like K&N filter oil....when i used K&N filters in the past, i would oil the filter then let it sit in front of a fan all night and install in the morning. That way, i knew the excess had dried.
Old Jan 2, 2004 | 03:39 PM
  #40
lowrider's Avatar
lowrider
What's all this talk about oil? The filter in the POP-Charger comes pre-oiled. That's why it's blue. It should be oiled about every 30K miles or so, though I'll probably do mine at 15K miles. Before your re-oil, you need to clean the filter, with JWT of K&N cleaner, hose it off from the inside out, let it dry, then re-oil (with K&N or JWT oil) per instructions. Before any oil is applied, the filter needs to be free of all dirt and oil, and needs to be clean. In a cloth filter clean means white in color.
Lou
