View Poll Results: Here is the y Pipes i have in mind
AAM
50.00%
STILLEN
20.83%
MEGAN
16.67%
NISMO
12.50%
Voters: 24. You may not vote on this poll
Best Y pipe for Agency Power exhaust
Old Jan 31, 2012 | 09:42 PM
hondatonissan's Avatar
hondatonissan
Exclamation Best Y pipe for Agency Power exhaust
hi guys and girls currently i have Agency Power exhaust on my 06 Z, and now im looking for a Y pipe to go with it, so opinion and review will be helpful. Thanks. Here is the y pipe i have in mind so far, AAM, Stillen, Megan, Nismo.
Old Jan 31, 2012 | 10:21 PM
R350Zz33's Avatar
R350Zz33
how bout hr
Old Jan 31, 2012 | 10:40 PM
Its a pipe shaped like a "Y." Why would one be any better or worse than the other?
Old Feb 1, 2012 | 03:21 AM
ndelgro's Avatar
ndelgro
You should add Motordyne to your list.
Old Feb 1, 2012 | 07:47 AM
A-Town-Z's Avatar
A-Town-Z
+10000 definitely one to consider.
Old Feb 1, 2012 | 10:13 AM
hondatonissan
Correct me if im wrong, im a new here but after doing research i found out that DE Y pipe pretty much restricted compare to any other y pipe out there. All y pipe the same ? If so then i dont understand why so many company out there actually paying big bucks to produce and reaseach on different style of y pipe for Z. Have u ever look at other y pipe and compare to stock one? The bend and diameter are different , so are all the y pipe still the same?
Old Feb 1, 2012 | 10:15 AM
hondatonissan
Wll do when i get home sir
Old Feb 1, 2012 | 05:49 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
How deeps your wallet?
Old Feb 1, 2012 | 06:02 PM
e30cabrio's Avatar
e30cabrio
I had it with the XYZ Y & resonator and it was great (but noisy)
Old Feb 1, 2012 | 06:42 PM
rdspencer83's Avatar
rdspencer83
Default Y-pipe
It does make a difference in your y-pipe if it constricts flow. Say your cat pipe is a 3 inch pipe and u buy a 2.5 inch y-pipe your gonna have a considerable power loss. Also If you look at the stock y u can notice that the angle of the pipe is higher which cause distorted flow. The Stillen y-pipe has least angle possible to allow it to still bolt right on.... very smooth flow! Other than that your right there is not much difference. I have a 07 Nismo with Berk HFCS, Stillen y-pipe and a NISMO cat back. It sounds really good not too loud. I starts singing around 3500 rpm. Its only loud when you want it to be. I can shift and 4k just buy the sound. The Stillen y-pipe was $230 not too bad for the considerable sound difference. It complement the Berk HFCs perfectly.
Old Feb 1, 2012 | 08:20 PM
hondatonissan
about 300
Old Feb 1, 2012 | 08:23 PM
hondatonissan
but from what i read so far, Stillen Y pipe is a ***** to install since it doesnt have flex pipes,beiside with out flex pipe does it have more chance to crack my exhaust mid pipe as well?
Old Feb 1, 2012 | 08:42 PM
2004Black350z
Exhaust Whore
I have no experience with a y pipe without flex but I'm sure you don't have to worry about it cracking anything other then the occasional test pipe. Depending on how fast you want it my best advice is either save up and get the best(Motordyne) or look for a used one on the marketplace. I had my AP paired with AAM and MD with res hands down such a smoother sound with MD.
Old Feb 1, 2012 | 11:25 PM
paulpoca2003's Avatar
paulpoca2003
If you dont have headers any y pipe should work fine but if you do have headers get xyz with resonator so its not raspy.
Old Feb 2, 2012 | 12:00 AM
terrasmak's Avatar
If you are buying a Y pipe to free up power, MOTORDYNE is really your only choice. If you want a Y pipe to say you have a Y pipe, just pick one.
Old Feb 2, 2012 | 11:10 AM
The subject of exhaust volume and exhaust velocity is as old as jesus. Altering either will alter horsepower and torque curves. Will the results be better or worse? The answer is a guess at best.
Old Feb 5, 2012 | 09:17 AM
GT-Rob's Avatar
GT-Rob
This is truth.
Old Feb 10, 2012 | 05:03 PM
hondatonissan
well i guess since im not going to get any headers anytime soon, i might just get me AAM then
Old Feb 10, 2012 | 06:14 PM
2004Black350z
Exhaust Whore
What um made u choose AAM?
Old Feb 14, 2012 | 07:34 PM
hondatonissan
because i read the reviews and saw the quality of it.
