Cold Air Intakes Mythbusted
Old May 4, 2012 | 11:52 AM
Fillipe's Avatar
Fillipe
Default Cold Air Intakes Mythbusted
pretty interesting test about cold air intake
<iframe width="560" height="315" src="http://www.youtube.com/embed/gCi2yo4UqPI" frameborder="0" allowfullscreen></iframe>
Old May 4, 2012 | 12:16 PM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
@ 2:17... What?
Old May 4, 2012 | 12:19 PM
MaelstrØm's Avatar
MaelstrØm
Ok, so this is somewhat good that they are using a dyno, and they are doing multiple runs. And they do show an improvement in both air temperature and power when done in the extreme case (just not a big one).
BUT...
Here is the fundamental thing missing: air pressure at speed against the front of the car. This is a big factor, because all of the horsepower spent maintaining speed is pushing against the air. You can't get this kind of pressure from a fan, since as we know, the force is directly proportional to velocity squared across the front (which is why cars max out around 220 mph). In F1 cars, this is enough to generate multiple Gs of downforce. This is also where open filters will suck in a lot more air, since the air is pressurized beyond 1 atm. In fact, if you could get the force of the air on the front of the car through a venturi filter, you could in theory get +1 atm on the airbox, the same as a regular turbocharger.
You will at least see a few psi increase a highway speeds. That is what you feel when you stick your hand out the window. Thus, their testing is missing a critical factor that, combined with their results, would produce bigger gains.
Thus, MYTH PLAUSIBLE.
Old May 4, 2012 | 12:36 PM
Barnabas's Avatar
Barnabas
National Z Club President
the other thing left out is tuning... you introduce more air you need more fuel.
terrasmak's Avatar
BUT...
I don't even know where to start on this, but with a perfect ram air system you will not get more than 2 to 3 PSI and that will never be positive. If your pulling 10psi vacumm , ram air may drop it to 7psi vacumm , never positive like an FI system.
Very true , also the supporting mods like headers, exhaust , cams etc etc Many parts do little by themselves, but work together as a whole.
Old May 4, 2012 | 01:33 PM
Now members will be putting the filter on the end of a long tube, and affixing it to the front bumper.
Old May 4, 2012 | 03:25 PM
R350Zz33's Avatar
R350Zz33
Saw this they dident use a cai made for that car they do somthing injen long tubes help to lean the car out a bit combine that and an exhaust setup and your pretty close to not needing a tune the tube will refine it but it gets it in the ballpark
Old May 4, 2012 | 03:40 PM
pss350z's Avatar
pss350z
Maybe im slow, or maybe its the longest run-on sentence of the month.
Old May 4, 2012 | 03:42 PM
Barnabas's Avatar
Barnabas
so it leans it out but the tune is close enough?? How does that even make sense.
If you introduce more airflow you need to add more fuel to see true power gains.
Old May 4, 2012 | 03:55 PM
ronn1's Avatar
ronn1
Well...it's a TURBO and trying to *cool* PRE boosted air won't do CHIT!
It's cooling the PRESSURIZED AIR that matters.... READ>>>>INTERCOOLER.
Old May 4, 2012 | 03:57 PM
PikesPeakZ's Avatar
PikesPeakZ
Originally Posted by Vivid Racing
@ 2:17... What?
What's wrong with a little *** play when checking out rides
Old May 4, 2012 | 03:58 PM
PikesPeakZ's Avatar
PikesPeakZ
This site sucks sometimes sorry for double post
Old May 4, 2012 | 08:03 PM
R350Zz33's Avatar
R350Zz33
Sorry posted this from my phone. What I'm saying is the intake helps to lean out the rich conditions caused by test pipes or hfc along with an exhaust there for getting the afr a little better in cheack but a tune will better refine it and help with drivability. Does that make more sense
Old May 4, 2012 | 08:57 PM
Contra's Avatar
Contra
the colder the "pre-boosted" air the easier it will be to cool pressurized air, so i dont see how it wouldnt serve a purpose?
Old May 4, 2012 | 09:01 PM
ronn1's Avatar
ronn1
you're not going to get any appreciable gains in trying to cool pre boosted air...waste of time. All efforts should be on cooling the ... PRESSURIZED SUPERHEATED air.
Old May 4, 2012 | 10:13 PM
PikesPeakZ's Avatar
PikesPeakZ
Did everyone seriously miss 2:17 in the video?
Old May 5, 2012 | 03:43 AM
Fitzys350z's Avatar
Fitzys350z
I dont see how you could miss it. that was full grabish.
Old May 5, 2012 | 09:49 AM
F2CMaDMaXX's Avatar
F2CMaDMaXX
This video has been doing the rounds of late, but i still had to look to see that grab :P
Old May 5, 2012 | 10:16 AM
JCITY's Avatar
JCITY
Cool could be right about this
Yep,I can see it comming...
Some type of screen covered with LEDS that goes over the cone filter stickin out about a foot from the bumper.With a HR,this would double the effect
and fun.
They are workin on this in Taiwan as I post.
Check E-Bay.
Old May 5, 2012 | 11:46 AM
ronn1's Avatar
ronn1
I didn't see a damn thing...and I looked 5 times at 2:17
