Plenum gasket
Old Jan 4, 2004 | 09:04 AM
Mapleleaf's Avatar
Mapleleaf
Default Plenum gasket
I am taking off my Plenum to get it polished , those that have done this did you replace that gasket.
Old Jan 4, 2004 | 09:14 AM
PhoenixINX's Avatar
PhoenixINX
Default Re: Plenum gasket
No, you will be fine running your stock gasket.
Be EXTREMELY carefully in putting the plenum back on however, as it is VERY easy to bend and ruin.
Old Jan 4, 2004 | 09:23 AM
Mapleleaf's Avatar
Mapleleaf
Thanks for the info
Old Jan 4, 2004 | 03:54 PM
Morris's Avatar
Morris
You are probably okay, but the gasket is cheap. I would change it just so you don't risk doing it twice. That is what I did.
Old Jan 4, 2004 | 06:01 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
If you do mes up the gasket...
I can get you a new one...
and all other OEM parts
Old Jan 4, 2004 | 07:35 PM
PhoenixINX's Avatar
PhoenixINX
Guys... relax.
It's a copper gasket which has no need to be replaced if he's careful.
If he bends it, is can be lightly tapped back into place. If he creases it, then sure get a new one.
Don't waste the cash if you can be careful with what is fine.
Old Jan 4, 2004 | 07:44 PM
Mapleleaf's Avatar
Mapleleaf
Thanks for all your concern will take it careful
Old Jan 5, 2004 | 07:11 AM
sschmuve's Avatar
sschmuve
How thick is the gasket? Can you add more to increase the plenum volume cheaply?
Old Jan 5, 2004 | 07:20 AM
PhoenixINX's Avatar
PhoenixINX
If I'm right Top Secret tried this.
Didn't look like a hot seller... you have to realize, you have only mm's until you hit the bar.
Old Jan 5, 2004 | 09:36 AM
sschmuve's Avatar
sschmuve
Their gasket is extremely overpriced for what it is. A few mm's height probably goes a long way when multiplied by the length and width. There is still the Crawford bar if you want to go a little higher. But I don't know if hood clearance towards the rear of the plenum would be an issue.
Old Jan 5, 2004 | 10:37 PM
Jason@Performance
Performance Nissan
I looked up the gasket today for a customer.. I believe it was something like $14 list? Dont quote me on it.. but somewhere around there...
Old Jan 6, 2004 | 06:35 AM
PhoenixINX's Avatar
PhoenixINX
The TS gasket was well over $100, and from the looks of it may raise it no more than 5mm.
The OEM should be right around that $14...
To me that's half a tank of gas!
Old Jan 6, 2004 | 06:39 AM
Jason@Performance
Performance Nissan
Wow gas in TN is that expensive too...
$100 gets you about a 1/4 of a tank here in cali....
Old Jan 6, 2004 | 06:54 AM
PhoenixINX's Avatar
PhoenixINX
OUCH.
It spiked the other day, hit $1.79... I got pretty pissy about that!
Old Jan 6, 2004 | 07:26 AM
roark's Avatar
roark
That spacer gasket was well over $500. The problem is that no one has any performance numbers on this. It may be just as good a mod as the Crawford plenum $/HP, but no one was able to validate it.
I was going to try to make one out of T6 aluminum, but my buddy lost his access to the CNC machine we were going to use. I thought about making one out of UHMW, but I think the running temperature of the plenum is too high for most easy to mil polymers.
Old Jan 6, 2004 | 08:56 AM
350zdanny's Avatar
350zdanny
I think my nissan dealer charged me $4.XX for my gasket when i bent mine. I keep one in storage now incase I do the same thing again. They were on back order for a while.
http://www.bulletproofautomotive.com...il.php?ID=1172
The above link is to the espirit power intake. I emailed some people about it but couldn't get any solid info. It looks to acheive the same thing as Crawford, but with less ugly (and probably less hp gain too).
Dan
Old Jan 6, 2004 | 05:52 PM
MY350Z.COM's Avatar
The spacer kit was made by Esprit and is ridiculously expensive for just a spacer. You have to remove the strut bar on that kit as well.
Old Jan 6, 2004 | 06:52 PM
lowrider's Avatar
lowrider
In addition to what Mike (err Victor) said, as I remember the motor mounts must be cut (lowered) so the raised plenum will clear the hood. Also, the Espirit doesn't equalize the Air flow to the front and rear cylinders. It just raises the whole plenum (back as well as front). So while the fronts now get enough mixture with the Espirit, the rears get to much. From all that I've heard, not a good mod.
Lou
Old Jan 7, 2004 | 06:34 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
How do you know it does not equalize the manifold? Hvae you seen it in person? For all we know, the gasket could be tapered so that the front is raised more than the rear......I'm conjecturing obviously, but it is possible.
The Esprit project car has this gasket installed on their car. While it is expensiove (everything from them is expensive), having seen videos of the car in action, the car is quite fast......and its still 100% NA.
If you want to retain the stock strut tower bar, the motor mounts must be cut 8mm. If you don't mind losing the strut brace, you can leave the mounts as is.
Old Jan 7, 2004 | 07:21 AM
sschmuve's Avatar
sschmuve
So what if the gasket raises it equally? The problem is that the front 2 cylinders are starved at higher rpm. The gasket reduces that, and probably doesn't affect the rear. It shouldn't matter if the other 4 get more plenum space.
