Pop charger issue
Old Jul 15, 2012 | 12:13 PM
llurz1's Avatar
llurz1
Default Pop charger issue
After waiting a long time I finally bought myself my first z. I got an 03 touring or mans sunset with 67k in awsome shape. A few days ago I installed the pop charger. I really love the sound of it but it feels like I lost a little. It of power off the line. I will probably just put the stock airbox back in because I love the quickness off the line but is there anything I can do to get it back to the quickness of the stock airbox while keeping the pop charger? Thanks!
Old Jul 15, 2012 | 12:42 PM
mickeyboi's Avatar
mickeyboi
You might want to give the car some time to adjust to the new increased amount of air flow. People normally suggest resetting your ecu so it can adjust to new changes. After I put on the HR y pipe and y pipe back exhaust, the car didn't feel right until a few days later when it adjusted properly. Give it some time and see what you think.
Old Jul 15, 2012 | 12:49 PM
llurz1's Avatar
llurz1
Okay I did reset the ecu when I installed it but it's only been a few days so I'll give it some time. Thanks man.
Old Jul 15, 2012 | 12:57 PM
mr. sparco's Avatar
mr. sparco
I'd go 06+ stock box (if you have an 03-05) with K&N panel filter over the Pop Charger.
Old Jul 15, 2012 | 01:59 PM
llurz1's Avatar
llurz1
I have been looking into this as well. The only think keeping me from ripping it out and throwing the stock airbox back in is I love how it sounds. I have been looking into plenum spacers. If I got a spacer would that bring my torque back to how it was with the stock airbox? If they are worth the money what spacer would you recommend? Thanks for the help.
Old Jul 15, 2012 | 02:16 PM
JCITY's Avatar
JCITY
The OEM air box does a damn good job with a K&N.I have a PopCharger.Did not experience any power loss although many have reported what you have encountered.
As mention,give your ECU a chance to readjust.Would have been a good idea to disconnect your battery before installing the JWT.You may want to disconnect the negative battery pole,wait overnite to reconnect.See what happens.
A plenum spacer is a good move.Basically its a piece of metal.Even though some guys will debate,all spacers pretty much workk the same.I have a Z1 spacer that cost me about $135.It works just as good as spacers costing twice as much.
Don't expect neck snaping performance from these bolt ons.Adding a cat back
exhaust system,maybe test pipes or HFC's, would be traditional mods.Get a tune after
all these ingredients to make everything work together.
You should get a more responsive Z!
Old Jul 15, 2012 | 03:31 PM
llurz1's Avatar
llurz1
More responsive is exactly what I'm looking for. I did disconnect the battery while installing the pop charger. Does the Z1 spacer come with all the hardware needed? Do you have a link to the one you got? Thanks for the help I'm loving the Z so far.
Old Jul 15, 2012 | 04:07 PM
bmyles's Avatar
bmyles
Just ordered it today: http://www.z1motorsports.com/350_g35...oducts_id=2854
Old Jul 15, 2012 | 04:18 PM
terrasmak's Avatar
Did you install the heat shield?
Old Jul 15, 2012 | 04:29 PM
llurz1's Avatar
llurz1
Yes I did. I would defiantly not say I lost a lot of power but it just seems like a lost a little low end punch. It could just be a bit of a placebo effect though and I need to get used to it.
Old Jul 15, 2012 | 04:43 PM
JCITY's Avatar
JCITY
Thumbs up Z1 spacer
Go to the Z1MOTORSPORTS.COM SITE.
Click on spacers.You probably want a 5/16" spacer.The OEM strut bar will clear the plenum.All the hardware comes with the spacer(bolts etc).
Its a easy install as long as you keep track of all the connections.
If you are not comfortable about install,have it done for you.You also may want to replace your tube going to the throttle body.I'm running a Berk
Z tube(check my veh pics for the set up).
Old Jul 15, 2012 | 04:49 PM
llurz1's Avatar
llurz1
Okay thank you for the help I will order it soon.
Old Jul 15, 2012 | 06:01 PM
Waiz's Avatar
Waiz
If everything was installed correctly you most likely are feeling a placebo effect.
The difference in HP is not something that you can accurately gauge without putting it on a dyno
Old Jul 15, 2012 | 07:37 PM
Itzcashew's Avatar
Itzcashew
by far to me the best mod I ever did was putting the OEM air box back on. After I installed plenum spacers the noise maker of a popcharger is worthless. Unless you want to listen to a slight whistling noise. But if I wanna hear a whistle I'd slap turbos on it and cry over being broke.
Old Jul 15, 2012 | 09:37 PM
Bmurray350z's Avatar
Bmurray350z
yeah you probably did lose hp/tq because all the popcharger does is heat soak. worst intake on the market. but cheap and sounds cool so everyone gets it and says it does wonders
Old Jul 15, 2012 | 09:48 PM
terrasmak's Avatar
That's funny , and false.
Old Jul 15, 2012 | 09:53 PM
Bmurray350z
I'm gonna assume that you have a popcharger on your Z?
Old Jul 16, 2012 | 11:48 AM
bmccann101's Avatar
bmccann101
there is literally nothing but fact in this post.
No one will listen tho..
sure...the ECU reset will let it re learn towards the factory targets, but those targets are still going to run the car towards lean w those mods.. unless determination and will power have been proven to chage the properties of ECU software lol.
It just is what it is.
PLENTY OF THREADS ON ALL OF THE abOVE OP>>> NO ONES GOING TO REHASH IT ALL IN THIS THREAD ALONE THO.. NOT MAD, JUST SAYIN..WERE ALL BORED HUNTING FOR GOOD THREADS TODAY, OR WED JUST BE FLAMING YOU LOL.
READ THE FAQS, LEARN ABOUT YOUR CAR AND YOU TOO WILL BE YODA.
07ZEKE
Aug 23, 2021 09:15 PM
_bit
Oct 2, 2015 07:49 AM
350z82
Oct 1, 2015 06:25 PM
