PPE Longtube Headers
Old Feb 23, 2013 | 08:04 PM
  #1021
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
Originally Posted by 03Screamer
I just did a quick comparison of your latest graph (w/ PPE LT's) vs your previous 322rwhp graph (w/ the stillen shorties and ART pipes). The weather conditions actually seemed to favor the PPE LT dyno and I also noticed the long tubes seem to give you a slightly fatter torque curve in the mid RPM's (likely around where the RPM's fall into after a shift), so the car probably wouldn't feel much slower at all...especially since you tend to feel the Tq difference more (especially after shifting) in the lower rpms than up top. I'd still throw a fatter exhaust on it...but thats just me
I might end up trying the SFR equal lengths (in a quest for ultimate power 6k rpm +) on my HR in a couple of months. I would then mate that up to a pretty trick 3.5" single, which would then branch out with a 1-3 collector into 2 2.5" Burns mufflers (to at least have some type of noise reduction) with the 3rd 2.5" pipe not having any muffler whatsoever. These 3 pipes would then exit in a triangle shape "^" that would be cut into the bumper just below the license plate enclosure...just below the floor pan. It would be fairly costly, but at the same time unique and done right the first time I feel/hope lol.
It probably sounds like I'm dreaming some type of fairytale...but if you know me, I'm certainy not haha!
Burns mufflers offers very little sound reduction btw.
  #1022
MM'08_350Z's Avatar
Well the car don't feel sluggish at all still breaks them tires loose in 3rd the RevShift Motor Mounts are also freaking awesome. I do not know what the duty Cycle for my 725cc injectors are but don't think it's over 80% and no less than 65%. I thought the Flat lined AFR was good?¿
Very Satisfied though.
Originally Posted by juicinjake
if you actually lost that much power you'd feel it. i have the exact same exhaust setup and it was definitely faster with the ppe's. i highly doubt its the tdx2... you really should have done a same day before and after if you wanted to know if you gained or not. id do a compression test if i lost that much. i cant see whats going on with your afr down below but it looks flat. is it the same value that it was before when u made 322rwhp? whats your injector duty cycle look like?
Old Feb 23, 2013 | 08:09 PM
  #1023
Vq.turbo.DremZ
Those numbers are on 109? Forgot to ask.
Old Feb 23, 2013 | 08:14 PM
  #1024
MM'08_350Z's Avatar
93 octane!!! Everyday driving. I didn't do the race fuel tune due to the loss of power. But I think I should have done it.
Old Feb 23, 2013 | 08:48 PM
  #1025
03Screamer's Avatar
03Screamer
You're comparing apples and oranges though. Your car had stock manifolds and cats (on a Rev Up) prior to installing the PPE LT's. Totally different scenario.
Edit: I definitely agree he/they should have done a baseline before doing the header swap though. Could be poorer quality fuel causing the dissapointing results, etc.
I'm already aware....with 2 Burns mufflers (which aren't nearly as noisy as most Vibrants mufflers) and a resonator after the Y merge, I should be able to achieve a sound level I could deal with for a weekend warrior/track car. Although I'd also consider a pair of Magnaflow straight thru mufflers (I always thought their mufflers sound fairly decent on the VQ)...but first I want to find out what muffler and piping Doran are using on their 370Z GS race car (which is basically a HR engine)...because damn thing is eargasmic to me haha! It looks like a Burn's muffler to me, but sounds pretty damn high pitched compared to the deeper sound that is often a trait of the Burns mufflers I've heard before. I need to ask Dwnshift on the 370z forums sometime soon to get an answer.
Here's a clip of their race car on the dyno (sorry I'm on my iPhone and am unsure how to embed the clip on this particular forum :/ )
Old Feb 24, 2013 | 05:34 AM
  #1026
MM'08_350Z's Avatar
^Sounds a whole lot like mine.
Old Feb 24, 2013 | 11:59 AM
  #1027
0jiggy0's Avatar
0jiggy0
If you indeed did lose power, could be anything from not properly taking advantage of the cam phasing to maybe your cams dont work well with the PPE's.
I highly doubt the Motordyne is causing any problems.
With everything you put into the car I would try and figure it out though.
Old Feb 24, 2013 | 12:29 PM
  #1028
Vq.turbo.DremZ
That golf cart is loud at :35. Is that the sound your looking for?
Old Feb 24, 2013 | 09:20 PM
  #1029
juicinjake's Avatar
juicinjake
agreed. thats true. i still dont think the tdx has anything to do with it. its a proven power maker, on this car as well as others. ive never seen a dyno where a tdx2 was outpowered by anything. that said, i dont think its an impossibility either. if he gains with a single id not only be suprised, but motivated to make the switch myself. i still think the issues lie elsewhere. the ppe's open the exhaust up a lot and they scavenge very well with the merge collector. thus more spent charge exists the cylinder and more fresh charge can enter the cylinder (in the ranges where the headers are the most efficient of course). to get the afr's back where they were before you'd surely have to add some fuel. i dont know. id just like to see them investigate further into the number variance before blaming the catback. its not like it was hurting it when it made 322... jmho. i mean a major DA shift can get you for 15whp easy. what was the DA before vs this time?
Old Feb 24, 2013 | 09:47 PM
  #1030
juicinjake's Avatar
juicinjake
yea that could be it too. tuning the cam maps is relatively easy. i did a lot of research on this on the supra forums a while back. those guys were really knowledgeable and were eager to share what they had learned. just have them zero everything out and then increase it across the board (or at least in the wot range) 5-7 degrees at a time until you max them out. then set the wot map so that it uses the phasing that makes the most power in each range and then move to the exhaust. ive experimented with mine a lot via street logs and it runs great... im trying to schedule some dyno time with a local guy now so that i can do just this. ive gone as far as i can go on the street. id love to see how your dyno changes with some in depth cam phasing tuning.
Old Feb 24, 2013 | 10:40 PM
  #1031
KingBaby's Avatar
KingBaby
Hardest Setting
Good to know...I brought a shitty laptop in hopes to buy the tuning software and it myself!
Reinstalling
Old Feb 25, 2013 | 08:30 AM
  #1032
redline06's Avatar
redline06
Originally Posted by KingBaby
Old Feb 25, 2013 | 05:23 PM
  #1033
Vq.turbo.DremZ
Funny, mine are wrapped as well. Mine are installed, need more time to drive it and get it tuned.
<a href="http://www.flickr.com/photos/56018946@N08/8509178934/" title="photo by s.daguio1, on Flickr"><img src="http://farm9.staticflickr.com/8229/8509178934_55df1c39f2_c.jpg" width="600" height="800" alt="photo"></a>
Old Feb 27, 2013 | 06:39 PM
  #1034
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
If there is any power lost its definitely not from the Motordyne exhaust. It performs excellent to 600+ HP and optimizes both HP and TQ from its continually expanding design.
Even a generic single 3" Y-back exhaust is nowhere near being a bottleneck in built NA 4.2L engines with much more NA power.
If this car lost power, something else is causing it.
Old Mar 4, 2013 | 05:50 PM
  #1035
2004Black350z's Avatar
2004Black350z
Exhaust Whore
King did your headers get that hot you had to Wrap em? Mine should arrive next week and idk if I should coat wrap or nothing at all
Old Mar 4, 2013 | 11:04 PM
  #1036
Vq.turbo.DremZ
If it means anything to you, my IAT are higher during idle. You already know the cramped space around the engine bay, it couldn't hurt either way.
Some Install notes.
Driver Side: Like others have said already the steering shaft has to come out. Pretty simple with two bolts. I also removed the A/C lines to the compressor (Mine had a leak anyway, HP hard line). Majority of the bolts can be done on the topside except the rear cylinder bottom bolt. Used a racket closed end wrench. Otherwise pretty straight forward.
[Other things in the way: Obviously intake and a electrical ground)
Passenger Side: Hard coolant line. was relatively straight forward. The rear bolt was difficult to get to for me. ( could be reached with a long extension and a swivel, or from the bottom with a wrench.) 5/6 bolts can be done from the top, the rear lower was difficult to get to again. Had several tries before getting in, be extremely patient. And as someone mentioned already theres two brackets in the way. One on the back of the alternator and one holding a sensor connection. It makes direct contact with the header primary.
Also as others have mentioned on my 06, it has five wires for the stock sensors. It also helps to test the wires prior to install as there are two black wires in their loom. You'll save time during install day. Also the passenger side 02 wires are significantly closer to the headers than the drivers side. Heat shield are really useful.
Random notes: seems almost impossible to use stock studs, But i never tried it but can only assume. Also it helps to have an extra set of hands to help to line up the flanges.
Sound: I run a full TI JIC resonated and Y. I actually have no drone at all but I do have rasp between 3000-3500. and during various spots on decel.
Still tuning but otherwise its feeling strong, will report later after tune at RT
Old Mar 5, 2013 | 02:13 AM
  #1037
bmyles's Avatar
bmyles
How much do these throw off your tune? I'm already tuned for plenum spacer and high flow cats so I'm just wondering how quickly I would need to get retuned switching to these. Seeing that I have a DE, I have a feeling with the smaller increase in power, there will be a smaller change in AFR.
Old Mar 5, 2013 | 03:43 AM
  #1038
denchan350gt's Avatar
denchan350gt
Some Install notes.
when are you going to RT I might come up for a nitrous retune. Ask Vince if he can overlay my cammed non rev with non stepped PPE headers to yours.
I know that you will have more since I'm auto just want to compare the headers to another car on the same dyno.
Are yours stepped or non stepped?
Old Mar 5, 2013 | 06:55 AM
  #1039
Vq.turbo.DremZ
Mine are non stepped with the reducer. Trying to piece a custom exhaust together before going to RT, but I will inform you when that happens. Have to still tune the MAF, I'm getting a slightly rough idle. Still have to track it down.
Old Mar 5, 2013 | 09:41 AM
  #1040
Vq.turbo.DremZ
I haven't data logged enough to see how much it's compensating however at WOT it was running into 11.5 range, at idle it fluctuates quite a bit into 16s. I've driven my car about 100 miles, but haven't done logging enough or compared to pre and post install. I mainly looked how far they were from my targets. Hoping to do this over the weekend. Will report over time.
Something to note also, my car actually is quieter in cabin after the headers during highway cruising, found that interesting.
