exhaust/intake
Old Jan 20, 2013 | 01:29 AM
RENFRO's Avatar
RENFRO
Well the day I see a dyno sheet showing higher numbers with a stock airbox vs the popcharger I'll be happy to. Most evidence I've seen suggests otherwise.
Old Jan 20, 2013 | 01:45 AM
bmyles's Avatar
bmyles
From what I've seen, the 2006 airbox is superior to the earlier models. It doesn't ingest any hot engine air, which is the main drawback of a lot of intakes.
Old Jan 20, 2013 | 04:45 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
that dyno thread of intakes was crap. wasn't done properly
Old Jan 20, 2013 | 09:23 AM
bealljk's Avatar
bealljk
Originally Posted by RENFRO
Your "opinion" is also false.
no no, my opinion is never wrong, neither is yours, neither is anybodys…you see how that works - it's an opinion…there is no right or wrong…it's just an opinion…
It's been quite some time since I worried about an intake and exhaust mod on my car...
Old Jan 20, 2013 | 10:00 AM
bmyles's Avatar
bmyles
At the same time, though, I was running 14:1 AFR after doing plenum spacer, hi flow cats, and catback. That's a little lean and ignition timing was not optimal. ECU can only do so much, and usually the most changes are at part throttle, not full throttle.
Old Jan 20, 2013 | 12:03 PM
bealljk's Avatar
bealljk
no doubt … but I believe the OP is considering a cat-back and/or an intake…no plenum, no test pipes, etc
back in 2007 (with my 2003 DE motor) with a AEM intake and a stillen cat back, I was at 246whp and my AF was just fine. Sure, there are many many variables...
ShineMaster
Apr 20, 2016 05:04 AM
Doggman9
Tuning
Jun 13, 2013 11:58 AM
abushong504
Mar 26, 2012 06:35 AM
ML_
Jul 25, 2011 12:48 PM
kgkeen101
May 27, 2010 04:35 AM
