Issue after MREV + 5/16 iso copper spacer install
Old Apr 18, 2013 | 01:46 PM
Si2350's Avatar
Si2350
Default Issue after MREV + 5/16 iso copper spacer install
I installed the mrev, IMG, copper tb heater and 5/16 spacer.
The car seems to run rough now, but it still accelerates fastly, i can feel the power from the new mod.
It just seems to be rough around takeoff- i feel alot of pedal vibration, is this normal?
Coated gasket with oil
Oil filler rubber not pinched between plenums
all bolts were torque to proper specs and in proper order.
I do not see any vacuum leaks
Input would be appreciated
Old Apr 18, 2013 | 05:52 PM
Si2350's Avatar
Si2350
I also forgot to mention my idle is stable, 5-600 rpm
Old Apr 18, 2013 | 07:58 PM
Z_on_TE37's's Avatar
Z_on_TE37's
Did u reset ur ecu ? All that intake modification will drastically effect that. Do the official ecu reset and idle air procedure and it should go away within 10 minutes of driving.
Old Apr 19, 2013 | 08:28 AM
Si2350's Avatar
Si2350
I always unplug my ecu while installing anything.
After further reading it seems i may not have enough clearance between my plenum and strut bar, i will check it later
Old Apr 25, 2013 | 11:15 AM
fataLblitz's Avatar
fataLblitz
might be your strut bar hitting against your intake manifold. Had this happen to me, checked to see if the strut was knocking against and sure enough it was. Felt like the car was driving like **** before i went and loosened it and made sure the spacers were on correctly.
Old Apr 25, 2013 | 02:44 PM
Si2350's Avatar
Si2350
Yes that's what it was, adjusted it and everything was fine.
My plenum has to good marks I it now though
350z82
Oct 1, 2015 06:25 PM
