my car wont start!! (after nismo CAI install)
Old Jan 22, 2004 | 04:24 PM
funtanillaa's Avatar
funtanillaa
Default my car wont start!! (after nismo CAI install)
i followed directions perfectly, it starts for like 4 seconds and shuts down
i dont think its the maf sensor....can someone help me?
Old Jan 22, 2004 | 04:34 PM
A3zrider's Avatar
A3zrider
See if your MAF is on backwards
Old Jan 22, 2004 | 04:53 PM
alex30327's Avatar
alex30327
Ditto!
If that does not work, reinstall the intake tube and make sure that everything is ecure, maybe you have a leak or something.
Old Jan 22, 2004 | 04:55 PM
mofoz's Avatar
mofoz
definetly the MAF sensor i would say.
Old Jan 22, 2004 | 05:39 PM
funtanillaa
didnt fix the problem...i called a mechanic and he said it could be a vacuum leak...
Old Jan 22, 2004 | 06:22 PM
Sins4u33's Avatar
Sins4u33
wow big problem! that sucks dude hope you get it fixed! good luck man sorry to hear that
Ben
Old Jan 22, 2004 | 06:39 PM
FairladyZ's Avatar
FairladyZ
It is either the MAF sensor not plugged in properly or any part of the intake tube is not connected properly.
Old Jan 22, 2004 | 06:41 PM
FairladyZ's Avatar
FairladyZ
Did you disconnect the battery? If so make sure those are tight. If the ground is loose the car will die.
Old Jan 23, 2004 | 04:11 AM
padam07's Avatar
padam07
If you check everything that the previous people mentioned and you still have a problem. Put the stock air box back on and see if the problem persists.
Old Jan 23, 2004 | 05:46 AM
kitkos's Avatar
kitkos
The mechanic is more than likely right. Have you checked that you got the vaccum tube seated properly on the new CAI?
Old Jan 23, 2004 | 08:50 AM
350zdanny's Avatar
350zdanny
I don't know.. I've run without vacuum tubes installed before and the engine didn't cut out. Also, the MAF plug only goes in one way, so if you forced it in the other way I'm pretty sure you broke it. I'd also recommend putting the stock airbox back on and checking if the problem persists.
Good luck with your trouble shooting. Keep us posted.
Edit- oh i didn't see that you were in Cherry Hill. If you want, shoot me an email and I'll drive down and help you out. dcp225@stern.nyu.edu
Dan
Old Jan 23, 2004 | 08:55 AM
daking350's Avatar
daking350
I had the same problem..I reinstalled MY MAF in BACKWARDS..Meaning it was reading airflow the opposite direction..Double check this..Its most likely the problem..I dont think a vaccume leak would be severe enough to make it stall..
Old Jan 23, 2004 | 11:15 AM
350zdanny's Avatar
350zdanny
daking -
you unscrewed your MAF sensor from the housing?
Old Jan 23, 2004 | 01:14 PM
funtanillaa
update:
i put the stock intake back in and it works fine...
maybe a defective CAI??...im a little annoyed right now
Old Jan 23, 2004 | 02:04 PM
daking350's Avatar
daking350
Originally posted by 350zdanny
daking -
No..I put the whole housing in backwards...Dont ask...It took me 6 hours to figure it out,cause I put in a fuel tap at the same time and thought it was the fuel supply...
Old Jan 23, 2004 | 02:07 PM
daking350's Avatar
daking350
I put it in like this..(WRONG WAY)
zimbo's Avatar
zimbo
I'm not trying to put you on the defensive, but exactly how would a metal pipe be defective?
--Steve
daking350's Avatar
daking350
as opposed to this..(right way)
Old Jan 23, 2004 | 08:00 PM
funtanillaa
interesting...so it matters what angle the sensor is at?
daking350, thanks for the pictures bro, they help alot
would it be possible if you could a picture or where the MAF plug should be in? cant really tell from the picture too well
thanks!
Old Jan 23, 2004 | 08:33 PM
roark's Avatar
roark
Not the angle, but the direction of air flow. Take a closer look at the MAF tube. When it is installed correctly, the 4 bolt end (that used to screw into the stock airbox) is toward the front of the car.
