Questions after Motordyne Exhaust + ART Pipes Installed
Old Oct 30, 2013 | 04:12 PM
Strumpp's Avatar
Strumpp
Default Questions after Motordyne Exhaust + ART Pipes Installed
Hey guys I just installed my Motordyne Tdx v2 and the ART pipes in my 2008 350z. I had a couple of questions about throttle response and start up. After I was done with the install I took it for a test drive to hear how it sounded (Amazing by the way, I recommend this system 100%). First thing I realized was that in the 1-3k rpm range it felt really unresponsive and different then when the stock system. I'm thinking a Tune is needed? Also, on start up (Cold or Warmed up) it almost dies and then goes back to idling fine. Any Suggestions?
Also, I'm getting a tune sometime within the next month.
Thanks
-Strumpp
Old Oct 30, 2013 | 04:34 PM
mcarther101's Avatar
mcarther101
Probably running lean.
Old Oct 30, 2013 | 04:35 PM
Z_on_TE37's's Avatar
Z_on_TE37's
Reset ecu and do the idle and throttle procedure
Old Oct 30, 2013 | 06:19 PM
Bmurray350z's Avatar
Bmurray350z
+1 ^
ecu reset will help. but you will still be running lean and a tune will be best to squeeze every hp out of it. congrats on the awesome exhaust setup!
Old Oct 30, 2013 | 06:41 PM
Strumpp's Avatar
Strumpp
Alright thanks guys! I will definitely be getting a tune soon.
And thanks Bmurray I love the Motordyne so far, its everything I was looking for and more. Its a really quality setup.
Old Oct 31, 2013 | 07:01 AM
Suwaidi's Avatar
Suwaidi
A tune should fix things up - Get one if you don't plan on switching out or adding mods anytime soon (to save on the cost of a retune).
http://uprev.com/dealers.php
Old Oct 31, 2013 | 07:04 AM
travlee's Avatar
travlee
Master
what intakes are you running. after i installed mine i was lean and hit 275 whp, after the tune i hit 286. let us know how you like it after the tune!
Old Nov 7, 2013 | 10:53 AM
Strumpp's Avatar
Strumpp
I'm stock for intake, deciding if I want to stay stock or get something else. Not sure yet. I am going to wait until I get my 4.08 gears to get it tuned because I don't want to have to get a re tune just to fix the speedo. Ill post my results when it gets tuned. Should be within the next month or so.
davidm350
Oct 31, 2015 02:28 PM
z33z_nutz
Sep 23, 2015 07:22 PM
_koubie_
Sep 20, 2015 06:34 PM
FromGtoZ
Sep 20, 2015 03:41 PM
hardkicks
Sep 20, 2015 12:28 PM
