350z Cai Sucking In Pebbles
Im about to pull the trigger on getting an Injen cai setup for my hr. I have short rams now, but they feel off and I don't like them. I'm not concerned about water. I'm not taking my Z mudding, plus I'm getting hydro shields for the filter so I think I am set. The only concern I have is a pebble breaking through the filter and getting sucked into the engine. I have searched around and have not seen anybody saying that has happened to them. Has anybody heard or have any experience with this happening?
Idk. Do they? I figured if a car in front of you kicks up a pebble, and the pebble happened to hit the filter, it would hit it at the speed that the car kicked it up plus how fast you are going. That pebble would probably be going pretty fast
I wouldn't worry about it if I were you.
The quality. They don't fit right. They bump up against the strut bar, and the crankcase breather hose is in an awkward spot, so the hose is bent. The clamps come loose over time, and it overall feels cheap.
It's inconsistent. Some days my Z is super responsive and feels great right from the start, but a lot of the time it seems like the power is in the very top end with none in the lower end. It feels sluggish. Another thing that weirds me out about that is sometimes in third gear, I'll gun it, and it almost stutters. It isn't always a constant acceleration in only third gear.
And I think they are holding me back. When I got the tune, I was short on the amount of power I made. Nobody could explain why it didn't make any power. I know it is just a number, but something isn't quite right. It can't really be too much besides the exhaust or intakes, and the intakes are questionable.
When they had it on the dyno, it made an odd resonating sound around 5-6k rpm. It wasn't something clanking around, you could hear it in the engine noise. The best way I could describe it is if you have ever heard two instruments play the same note, and one is flat, it's the "wavy," kind of sound that you get. The tuner had to change a lot of things to get it to make some kind of bare minimum acceptable power, and I think that if I get a more reputable brand of intake I could fix some of these issues.
and what makes you so sure it's the intake?
