DC Sports Headers..$315-395
What are the stock manifold made of? I'm guessing that it is very unlikely that the stockers are stainless (at least I know in most vehicles they are not) so I think the ceramic types would last at least as long as the stockers would. Anyone able to confirm the stock material?
-D'oh!
-D'oh!
Performance Nissan
Performance Nissan
I guess we will have to see what these can do...
the Nismo Headers still have the largest collector out of all of them...
and the "new" nismo headers are avialble now...
so I gotta get a set and open them up and see whats different from the older ones...
If the stocks are cast iron, then I'm thinking the ceramic coated mild steel version would last at least as long as the stocks would, and probably longer. Maybe some one with some experience can confirm this?
I think the only conern with the coating would be if it chips off or something, but that seems very unlikely given the placement of the headers.
-D'oh!
-D'oh!
Performance Nissan
Performance Nissan
If im going to go in there and change out my headers, im going to do stainless steel because I do not want to have to go in there and change them any time soon...
id besure your exhaust has the flex piping in the Y-pipe if your gonna go with mild steel headers...
stainless is not always a superior material. Just with any metal there are good grades and cheap grades. Good mild steel is better than cheap stainless. I am not sure what grade they use yet, but I can tell you we have used past headers from DC interchageably depending on the customers budget (stainless being more costly), and have never had an issue with either one.
I cannot see how the stainless ones vs mild steel would put anymore demands on the Y pipe. Nearly every aftermarket Y pipe I have seen has a flex provision anyway
Performance Nissan
Performance Nissan
no im not saying all duals are bad...
its a little different with the duals, since they transfer weight a little differently...
you have to think when a car goes over a bump everything moves... if the exhaust was not supported by shock absorbing rubber, then the vibration from running over pavement even will eventually crack welds...
flex pipes help reduce that effect...
i am not saying if you dont have flex pipes the welds in your header flanges are going to come apart... but it could happen...
basicly anything can happen.. but the more precautions you take, the least likely they will
seagrasser
Oct 11, 2015 03:27 PM
