Straight Test Pipes Ideas for stock exhaust
Old May 24, 2014 | 08:14 PM
04SilverBulletZ's Avatar
04SilverBulletZ
Default Straight Test Pipes Ideas for stock exhaust
Looking for straight test pipes to replace my converter. Just wanting a louder exhaust note mainly. Unfortunately I cant afford to shell out $1500 bucks for a full catback sys. I like Berks so far...thoughts?
Old May 24, 2014 | 10:07 PM
xman2yman's Avatar
xman2yman
I have the Z1motorsport TP and they are good so far zero complaints
Old May 25, 2014 | 12:18 AM
yonkanif06's Avatar
yonkanif06
I got berks on mine before getting a catback. Honestly it doesn't make it that much louder but you can hear the difference, it will sound a little raspy but eh I liked how it sounded. Hope your OEM cats aren't as much as PITA to remove as mine were.
Old May 25, 2014 | 12:24 AM
superstuddc27's Avatar
superstuddc27
Love test pipe sounds.. would do mine if it didn't smell so bad and wasn't illegal.
Old May 25, 2014 | 06:09 AM
HR.R-CING's Avatar
HR.R-CING
Motordyne ART Pipes
Old May 25, 2014 | 09:14 AM
soc_monki's Avatar
soc_monki
i got ebay test pipes...50 bucks. 2.5 inch...decent quality too. it was more of an experiment but hey, its pipe. welds actually looked pretty decent. was just glad to get rid of the cats...
Old May 25, 2014 | 11:19 AM
Gumby Gone Wild's Avatar
Gumby Gone Wild
Originally Posted by HR.R-CING
Motordyne ART Pipes
This. Have patience, buy quality parts, avoid extra frustration.
Old May 25, 2014 | 01:03 PM
ronn1's Avatar
ronn1
I see you're from Calif? Just be prepared to swap them out come smog time.
I just failed the sniffer with Fast Intentions HFC (same core as Berks..300cell). They will be getting rid if sniffer some time later this year, but you'll fail visual and still may fail the*new* OBD scan. If you want to create a better sound, you can find a nice catback for $900 (Gemini which I have) or get a take off from those on sale here. BTW, car will NOT perform as well in DAILY DRIVING with HFC or TP..I know this for a fact. Low end will be lacking and throttle less responsive. Shifting up with lift throttle is not as smooth either. I found this out recently when I put my cats back in after driving around with HFC for 2 years! I'll never go back. Just my 2 cents.
Old May 26, 2014 | 09:23 AM
I.O.'s Avatar
I.O.
I agree as long as they are the v3, I had v1 and they cracked causing the resonense to break off
Old May 27, 2014 | 07:04 AM
RENFRO's Avatar
RENFRO
Test pipes are fine. I run Z1 Test pipes. I also ran V3 ART pipes, but they robbed power on my setup.
Standard test pipes are the best bang for your buck
Old May 27, 2014 | 08:44 AM
04SilverBulletZ
This. Baught both Z1 intake & test pipes. Did some more research heard many reviews on these and luckily I have a mechanic lined up to help pass smog But I'm curious what needs to be done to get rid of the check engine light?
Old May 27, 2014 | 11:42 AM
RENFRO's Avatar
RENFRO
You should be able to run these: http://www.z1motorsports.com/350_g35...oducts_id=3736
That should keep the engine light off
Old May 28, 2014 | 06:52 AM
04DaytonaZee's Avatar
04DaytonaZee
Test pipes on 350z oem exhaust systems generally sound pretty horrible. You sure you don't want to plan on a seperate catback/muffler setup? Or HFC to help eliminate rasp?
Old May 28, 2014 | 01:09 PM
ronn1's Avatar
ronn1
You will not pass Ca smog with TP (or HFC ) if they still use sniffer at that time. Visual on TP will take a very *friendly* tester and they're making the visuals tougher to pass with the new OBD only testing. Good luck...as I said I failed recently with HFC on sniffer alone.
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
z33z_nutz
Sep 23, 2015 07:22 PM
Tylerx7z33
Sep 21, 2015 01:43 PM
FromGtoZ
Sep 20, 2015 03:41 PM
Red G Coupe
Videos
Sep 8, 2015 08:36 AM
