Nismo Y-pipe question
Old Feb 6, 2004 | 10:30 PM
wakaZ's Avatar
wakaZ
Default Nismo Y-pipe question
Just wondering if the Nismo Y-pipe would bolt up to the stock exhaust.
tia
Old Feb 7, 2004 | 12:02 PM
DavesZ#3's Avatar
DavesZ#3
They appear to be about the same length - about 35" from flange to flange. They are a different diameter though. The stock is 60mm pipe, the NISMO is 76mm. With a different diameter, the bolt spacing on the flanges might be different. There's really only one way to find out -- try it out.
Old Feb 7, 2004 | 02:34 PM
KJY9's Avatar
KJY9
I've got the Fujutsubo which is 80mm IIRC, and it bolts on perfectly. I've never heard of anyone having problems with either the Nismo or Fujitsubo
Old Feb 7, 2004 | 07:31 PM
rodH's Avatar
rodH
does the Y pipe with the Nismo exhaust and if NOT what is it for, how much does it add??
Old Feb 8, 2004 | 05:13 AM
wakaZ's Avatar
wakaZ
Thanks guys, got a PM from Jeff@Performance. He said that it will fit. He is running the Nismo exhaust with the JIC Y-pipe.
I was also thinking about guys running other brands of Y-pipes but still using the stock exhaust and I kinda thought that it should fit if they are.
Old Feb 8, 2004 | 05:14 AM
wakaZ's Avatar
wakaZ
OK then...gotta post in the classifieds
Old Feb 8, 2004 | 01:53 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
NISMO Y-Pipe is a Fujitsubo Y-Pipe... the JIC Y-Pipe also bolts up to the stock exhaust...
the NISMO Mid Pipe does NOT work with the stock muffler... the piping is not long enough (or is it too short i forget) but either way it doesnt work with the stock muffler... (the mid pipe that is)
Old Feb 8, 2004 | 05:17 PM
wakaZ's Avatar
wakaZ
Thanks Jason, just wanted info on the Y-pipe, the thing about the mid-pipe not fitting is also good to know
Old Feb 8, 2004 | 08:12 PM
OCG35Coupe's Avatar
OCG35Coupe
Japtrix sales a midpipe that does fit the stock muffler...its the same 3" diameter as Nismo Y Pipe.
Although i heard it doesnt sound too good with hi flow cats.
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
