opinions needed towards test pipes
Old Apr 5, 2015 | 11:21 AM
D.R0905's Avatar
D.R0905
Talking opinions needed towards test pipes
Hey guys, just need a few opinions on what y'all think is a good test pipe for the z. I was thinking of a z1 test pipe (currently out of stock) I was thinking about berk and kinetix. Some inputs would be awesome!
Old Apr 5, 2015 | 01:04 PM
Dude1312's Avatar
Dude1312
ART pipes
Old Apr 5, 2015 | 02:42 PM
Toneloc's Avatar
Toneloc
I have z1 HFC... They are great... Can't go wrong with a pipe with welded phalanges aka test pipe lol.... If you're in a emission area no test pipe... Also with test pipe expect raspy exhaust
Old Apr 5, 2015 | 02:46 PM
sauer420's Avatar
sauer420
ART pipes will not create a raspy sound or throw CEL, but they also will not pass a visual emissions inspection whereas some high flow cats will.
Old Apr 5, 2015 | 03:28 PM
soc_monki's Avatar
soc_monki
i just have cheap Ebay test pipes (M2). the best are probably ART pipes, but compared to other test pipes i dont know if i would spend 200+ on just some pieces of pipe. had a couple cracks in mine (thanks Nismo exhaust) but once welded and a different exhaust put on havent had a single problem.
Old Apr 5, 2015 | 04:16 PM
Built4Adrenalin's Avatar
Built4Adrenalin
Those were such a good idea for the Z man! I'm super stoked with mine! They were also one of the hardest parts for me to get good answers on. I went with the Invidia test pipes (without the resonater and replacing the factory resonater with straight pipe to factory exhaust no headers yet either unfortunately) and I am very happy with the result! The only con about them that I can see is a lil crackle above 3,000 rpms unless your at full operating temperature! Other than that which I usually never do anyway, they added a very nice noticeable tone and a noticeable improvement in throttle response and torque!
Old Apr 5, 2015 | 06:04 PM
GreyZ33Track's Avatar
GreyZ33Track
resonated beluga ebay pipes.....sound very good with my Greddy exhaust. The did rattle on the W brace...had to put is spacers under it and problem solved..great bang for the buck... no rasp until 5k rpm.
Old Apr 5, 2015 | 09:05 PM
BikesNZs's Avatar
BikesNZs
I have the z1 non res test pipes. they fit great and were easy to install. No check engine light either. my only complaint is that I seem to have a distinct rasp at around 2700 rpm but its not that bad. Also have the X02 exhaust with the magnaflow resonated x pipe. No drone whatsoever, sounds mean and fairly loud, get compliments on it all the time.
Old Apr 6, 2015 | 07:31 AM
NiLL's Avatar
NiLL
Z1 non resonated it a 2.5" where as the stock is 2.25 as well as a lot of the dual exhaust systems. Make sure you are matching up pipe sizes. ART pipes are gods gift to exhaust, and for the love of god DON'T buy non resonated test pipes on the Z.
Old Apr 6, 2015 | 08:22 AM
Syner's Avatar
Syner
As others said: ART. If you're set on test pipes make sure they are resonated.
Toneloc's Avatar
Toneloc
Art cost allot of money... Z1 doesn't and does the same thing other than noise cancelation the art has...
Old Apr 6, 2015 | 09:45 AM
D.R0905's Avatar
D.R0905
Art seems promising but a little high on price. What's the difference on non resonated and resonated test pipes? Just noise? And I live in a non true inspection area. He just drives the car and checks my lights as gives me the sticker weather I have a CEL or not.
Old Apr 6, 2015 | 10:58 AM
Built4Adrenalin
Honestly, truth be told...a test pipes a test pipe. As long as it is good quality steel, TIG welded and fit precise with good gaskets and a nice seal with factory O2 sensor ports the rest of the cost is all name! It's literally like 3 ft of pipe each with a 15 degree bend and a threaded hole with a mounting bracket at either end, those are the only 2 welds. If you get pipes without an o2 sensor corrector and it does trip the light, weaponR make 30-40 buck solution! Their own CEL corrector and clearer that doesn't interfere with any other code not pertaining to emissions. The resonator settles all of the wild combustion deposits and inconsistent exhaust emissions and smoothes them out into an even direct pressure toward the next stage of your exhaust. In other words, generally not as noticeable volume difference, but a noticeable tone difference and of course throttle response! I do not have the raspy or crackle tone as long as I start my car and let it idle 5-15 minutes depending on outside temp, but from cold start until operating temp 3-5000 RPM definitely some crackle....no big deal! Don't bust your wallet on killer big name irrelevant parts, save it for the technical complex parts that you just feel better about paying for the name to have the peace of mind that you bought an overpriced piece of excellent reliable technical equipment! Anyway, hope this opinionated rambling helps out!
Old Apr 6, 2015 | 01:16 PM
D.R0905's Avatar
D.R0905
Love this reply! Lol that's my point of view as well, that's why I'm looking for something cheap wise. I got better things to drop abiut $500+ on a piece of pipe that's bent. But thank y'all for your inputs! And it looks like I'll be going with the z1 test pipe. I did a little more research and asked around on a different forum. The top two were z1 test pipes, and kinetix test pipes, but I like the sound of the z1 a little better. Y'all are great guys!
Old Apr 6, 2015 | 10:26 PM
dmanley317's Avatar
dmanley317
I have invidia test pipes on my 04
Old Apr 9, 2015 | 06:47 PM
m e l l o w's Avatar
m e l l o w
Ran AAM test pipes on my 03'. Nothing special about these vs other Test Pipes . They did NOT throw a CEL ever.
Old Apr 13, 2015 | 02:56 AM
dSpaceman's Avatar
dSpaceman
Currently running Invidia Gemini catback, thinking of deleting cat & getting Berk test pipes. Hope it'll amplify the sound more.
Side note, if you're looking for opinions, try searching other threads with reviews on specific set ups. Pretty sure starting a thread on an opinion based question is an infraction.
Old Apr 13, 2015 | 05:28 AM
travlee's Avatar
travlee
Master
the resonator on the art pipes does more than just add sound, tony obviously knows his shiiiit since he is a freakin rocket scientist
https://my350z.com/forum/intake-exha...-pipes-48.html
Originally Posted by Hydrazine
In my days as a rocket scientist at Marquardt designing rocket engines for JPL there were many challenges in ensuring the performance and reliability of the rocket engines.
One of the greatest challenges was designing an injector that could produce smooth and stable combustion in the combustion chamber. There were occasionally these acoustic resonances (tangential modes) in the combustion chamber that could start a run away condition where it could quickly destroy the engine. To address this problem we used Helmholtz resonators inside the engine to damp out the tangential acoustic resonances. A tangential resonance was a shockwave that would spin like a tornado inside the combustion chamber at 20K Hz. Much like ping or detonation in a internal combustion engine, this tangential mode would scrub off the boundary layer and radically increase the heat transfer into the chamber walls and result in the engine overheating.
Helmholtz resonators were the solution to these tangential waves. By properly tuning the Helmholtz resonator to the frequency of the tangential mode you could either magnify or eliminate the destructive shockwave.
After studying the application of Helmholtz resonators in depth I began to see how they could be used in a range of applications other than rocket propulsion. Particularly in automotive. If you have studied header design it is clear their function is all about using exhaust acoustics to increase scavenging. ART pipes do the same thing but in a different way. Headers use 1/4 wave resonators to make power. ART pipes use Helmholtz resonators to make power.
Traditionally, if you already have an intake, headers, test pipes with a full catback exhaust and tune, that was the end of the line. There was no more left to gain. ...But not any more.
This is Motordyne's debut of the patent pending Advanced Resonance Tuning (TM).
The plot below is without exhaust cam phase tuning. The ART pipes respond very well to cam tuning.
Regular test pipes always result in a large loss of low end torque. Compared to test pipes, the ART pipes produce a large gain in low end torque that is clearly felt and can be very usable for auto-cross or powerful launches in drag racing.
Old Apr 19, 2015 | 11:44 PM
Golden_Armz's Avatar
Golden_Armz
Just bought Megan racing resonated test pipes. $150. Like the person mentioned above, it's just test pipes. Not gonna spend 600 for test pipes for similar results. I can deal with a little bit of rasp... No big deal. Saved me almost 400 dollars.
Old May 16, 2015 | 05:20 PM
eZekiel_HR's Avatar
eZekiel_HR
How have the Megan test pipes treated you so far?
