Loud exhaust noise under hood and power loss
Old Jun 20, 2017 | 07:06 PM
FalseAngel's Avatar
FalseAngel
Default Loud exhaust noise under hood and power loss
About 2 months ago I put a Invidia Gemini Catback exhaust on my 350z. Car sounded great up until recently. One morning the car had a rough idle that went away after a little rev and driving. The next week the rough idle came back and the check engine light came on as well. Had the codes pulled which came back with a misfire on cylinder 5 in which I was told was the plug closest the the driver. Did a tune up in which that plug that is closest to the driver was maybe hand tight if that as I was able to take the plug out with just the spark plug socket no wrench. I replaced the plugs and the idle is back to normal but now when I drive the car at load roughly 2500 rpm there is a loud pingy type sounding exhaust sound from the engine bay or just behind it. Along with the loud sound I seem to have lost most of my power. If I pick up speed gradually it seems fine but to pick up speed fast it seems to have now power. Brought it to an exhaust shop they said no exhaust leaks and he tried to tell me that the noise was my exhaust system (I know that is false information) Only thing I can think of is the misfire damaged the catalytic converter by not burning off the fuel or something? Any ideas of what else it could be?
Specs of car are:
2003 Nissan 350z ATX
Skunk2 Racing plenum spacer
Injen Short Ram Intake
Invidia Gemini Catback Exhaust
Old Jun 21, 2017 | 03:26 AM
travlee's Avatar
travlee
Master
how are we supposed to diagnose a car from behind a keyboard....
Old Jun 21, 2017 | 04:56 AM
Atreyu'z 350's Avatar
Atreyu'z 350
Specs of car are:
What is your mileage? Is it a 5AT?.. From what you described, it sounds like you may be having some detonation. What type of spark plugs did you replace your old ones with? What octane fuel are you running? Did the CEL come on after installing the new plugs?-Assuming you cleared the previous code that was being thrown by the old plugs..
Old Jun 21, 2017 | 06:54 AM
FalseAngel's Avatar
FalseAngel
Didnt get the previous codes cleared. I replaced them with Bosch double platinum and running 93 octane. It is a 5AT with approx. 175,xxx miles. ran great, sounded great and had no problems until this misfire.
Old Jun 21, 2017 | 07:23 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Clear all codes and start over again. Get yourself a regular OBD-II scanner/reader so that you can pull the codes immediately when the CEL illuminates. I would guess you'll get a generic P0305 AND other codes, so you MUST....
Compare with NISSAN-SPECIFIC DTC definitions lists available on the web to get you pointed in the right direction. If this doesn't reveal anything substantial, you may need to go to a Nissan dealer or Nissan specific shop that uses CONSULT, the Nissan-specific diagnostic tool to get a full-on read of your OBD system. (Unless you wanna spend the big bucks for your own CONSULT-III setup which is available.)
A generic P0305 code could mean just about anything in the ignition sequence from the spark plug on to the coil pack to the ECM itself. CONSULT will be more precise than a general code but at least your personal scanner will confirm something going on in the ignition sequence.
If I were a betting man, would double down on a bad crank position sensor.... or thereabouts based on your mileage and symptoms.
But as Trav said, no real way to diagnose virtually without putting hands on it.
Old Jun 21, 2017 | 08:57 AM
Atreyu'z 350
^What he said.
Plug type, good. Gas rating, good.. It could be something as simple as a bad coil or injector on cylinder #5, or it could be something more serious such as bad rings or a rod bearing. When you replaced your spark plugs, did you come across any oil pooling in cylinder #5's spark plug well?
Old Jun 21, 2017 | 06:09 PM
FalseAngel's Avatar
FalseAngel
Yes there was some oil in cylinder #5's plug well because the plug was not tightened at all some oil did get in there. I do need to replace that coil on boot thing as the one that was there for cylinder #5 came apart when pulling it out and it had some oil in it. I will try to get a video clip of the sound it is making while driving tomorrow to help. As I said though, the rough idle is gone just no power and loud exhaust sound under load at about 2500 rpm.
Old Jun 21, 2017 | 07:33 PM
jhc's Avatar
jhc
General & Tech Moderator
Specs of car are:
You need a tune /reflash to compensate for your Intake/Exhaust mods. You simply cannot bolt-on different products without an Up-Rev adjustment, it will never run correctly, and you will not realize the gains from your mods. gl!
Old Jun 21, 2017 | 08:07 PM
Neeleo_Z33's Avatar
Neeleo_Z33
Just get ur CAT checked...u might be having a restriction.
Old Jun 22, 2017 | 11:45 AM
Atreyu'z 350
Ok.. I would do a compression test to make sure that cylinder is healthy, and if it is, I'd try replacing that #5 coil pack(and get the bolt for it).
