Cold air intake HELP
Old Aug 22, 2024 | 05:31 PM
BuckeyeBoys's Avatar
BuckeyeBoys
Default Cold air intake HELP
After closer inspection on our new 05 roadster it looks like this cheap cold air intake is shot! I saw the crappy install but did not notice the filter had deteriorated. I need a replacement ASAP. Recommendations please? IT looks much shorter than most of the ones I'm seeing online. Is that the MAP sensor just above it? Thanks
Old Aug 22, 2024 | 07:15 PM
icer5160's Avatar
icer5160
Yes, that's the OEM MAF mounted in the plastic tube portion. You're in Ohio, so you probably have more aftermarket intake options than I have being in CA. But if it were my Z, I would get an OEM airbox (preferably from an 06 Revup) and slap in a good quality filter cartridge. Something like THIS.
If you want to continue with an aftermarket option. I like the Mishimoto unit for the VQ35DE. It still uses a cone style filter, but the box design seals nicely with the hood to keep the hot air out.
Cheers!
-Icer
Old Aug 23, 2024 | 04:42 AM
Heel Til I Die's Avatar
Heel Til I Die
Pretty sure I have the OEM air box assembly from my '05 in my garage somewhere. PM me if you want it. Just pay shipping and it's yours.
Mishimoto is a good aftermarket option. I also like the Stillen Hi-Flow Intake kit since it also has a barrier acting as a heat shield.
Old Aug 23, 2024 | 05:05 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Go with the OEM airbox, as you won't get any gains from the aftermarket ones (without a tune). The OEM design is a good design, with an easy way to check, clean or replace the filter element.
FARHANTAZ
Aug 12, 2024 08:34 AM
xS3CT0Rx9
Aug 8, 2018 02:14 PM
New2350
Apr 17, 2006 02:07 PM
zach1288
Mar 16, 2005 08:43 AM
ACEMAN
Sep 8, 2003 09:26 AM
