Kinetix > you
Old Mar 5, 2004 | 01:02 PM
lsdunique's Avatar
lsdunique
We have a solution we are finalizing here today/this weekend to the torque problem. While we personally havent had any problems, we think more "headroom" and a larger margin for error should be allowed. I will make an official post.
Old Mar 5, 2004 | 01:20 PM
coachk's Avatar
coachk
lsd,
If you can, would you check to see if my plenum went out yet.Order #1068 I purchased it on 2/25.
PM me please
Coachk
Old Mar 5, 2004 | 01:22 PM
kgb's Avatar
kgb
Default Re: Re: Re: Kinetix > you
Originally posted by zxsaint
Ever consider that it's the installation thats not for you?
I cracked one too, but it was before the torque specs came out. Had I read them, I probably wouldnt have overdone the force (which I tend to do).
I would install the plenum myself and could probably do it without cracking it, I'm sure. But it does sound a bit fragile especially for $400. If I took my car to the dealer for engine reasons and they had to remove the plenum, I'd say the likelihood of them cracking it is pretty good. If you (or anyone) can live with this, go for it. I’m just a bit uneasy about the potential of it cracking during an installation.
Old Mar 5, 2004 | 01:29 PM
lsdunique's Avatar
lsdunique
I understand your concerns andthey are very valid and I also agree with these concerns. While you don't want to worry about the install, we don't want to worry about your install as well.
I have posted a thread regarding an update to eliminate this worry.
Old Mar 5, 2004 | 02:09 PM
kgb's Avatar
kgb
Thanks.
Old Mar 5, 2004 | 02:24 PM
Duflacci's Avatar
Duflacci
well I got mine installed I used a thin film of permatex red to give the flange a better seal and I didnt have any problem at all...but I did find the gaskets going from the RT cats to the y pipe were blown out so I replaced them with some better all metal ones ......I also ran a ground from the Throttle Body to the engine to cover all bases...I reconnected the battery and turned the ignition on for 10 seconds off for 10 on for 10 and off again....I am very impressed with this plenum.....it stays luke warm and never gets hot .....which I think would help by allowing cooler air in....I recommend it....
Old Mar 5, 2004 | 02:54 PM
lsdunique's Avatar
lsdunique
Glad to hear your install went smoothly, I hope you read my post about a revision offer, although you seem to have everything under control. Did you use an actual inch/lb torque wrench or did you just use finesse?
Glad you are happy with the product, if you have any questions, comments, or suggestions please email me at jamisonl@msn.com
Old Mar 5, 2004 | 09:44 PM
SungNamZ's Avatar
SungNamZ
Indunique, my install is complete. VERY satisfied. Had the $69 torque wrench from Sears. Per our conversation, started at 20 inch pounds, ran engine for a few minutes, had NO leaks. Tightened to 36 inch pounds and again NO leaks. A fellow "Z" owner and I decided to celebrate with a couple glasses of wine. Thus, things were allowed to dry for a couple of hours. Took it around the block. NO leaks! Sounds, AWESOME! Using "Butt Dyno" as a measure, more PONIES. Will put it too a thorough test tomorrow.
Old Mar 6, 2004 | 01:59 AM
Duflacci's Avatar
Duflacci
Finesse
Old Mar 6, 2004 | 05:44 PM
350xfire's Avatar
350xfire
A guy who drinks WINE after working on his car???? WHAT!!! LOL!
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
syf0n
Apr 8, 2004 01:02 PM
all_bark
Feb 22, 2004 11:11 AM
alex30327
Dec 24, 2002 06:47 AM
