My AEM vs Pop-charger dyno's...
Sounds true, but I have kept tabs on my plenum after running it hard. Last time out at the track I was surprised I could hold my hand on it, it was warm, but not burning. I've def felt way hotter plenums after running it hard than the Z's....but as far as the Crawford vs Kinetix-I would also say the Kinetix has the advantage.
Guest
Posts: n/a
Originally posted by FLY BY Z
Heat soak is worse when you let the car sit. Once you stop moving there is no coolant flowing, no air moving over the motor, through the radiator, etc. The motor will actually get even hotter for the first 15-20 minutes before it begins to cool down. You would have to let it sit for like an hour or more before you could get rid of the effects of the heat. Sort of sucks.
Originally posted by hfn
Only sort of. Technically the heating cycle will be during the first 5-10 minutes before it begins to cool down.
Yes, lol, Vandy, the stock plenum is aluminum. It also restricts the front cylinders by 35% or 25% or whatever Doug reported. Oh Vandy, the stock suspension is aluminum. It also makes a bouncy ride and causes feathering. Is stock always good?
Alberto, I burned my hand on my stock plenum. Maybe your car runs cooler or something. I burned myself the second day I had the car. Not really something I brag about, but it is suitable here.
After running my Crawford plenum, I was SHOCKED I could put my hand on the plenum without it being TOO hot.
Good job guys on the coating! VERY heat resistant!
Right. We know who you are not.
Though... who in the world are you?
If you research hfN's profile you see he has over 150 posts but registered tonight. You also see that there is not 150 posts made by him but rather 4 (at this point). Is this a mod, a hacker, or what?
Originally posted by Alberto
WTF
I thought HFN didnt own a plenum? Maybe hes been drinking again, I remember reading him post once and he said he had been drinking, I dunno weird
WTF
Thanks Vic.
Originally posted by PhoenixINX
Whoever you are... you're right on the coating being "Cool" to the touch... even after being run hard.
on the original issue of the CAI's.
i have a g35 running the popcharger, but the concept should be the same.
anyways, CAI's are supposed to have more gains on the dyno...and it is proposed that on the open road with the high pressure zones in the bumper, they give less gains.
also, i remember jason telling me that the nismo is acually better than the Popcharger for the 350Z. are the AEM and Nismo the same? i dunno. im a G guy.
will you be doing another dyno with the plenum changed? id like to see that a lot. =) but then again, im a dyno freeloader.
Originally posted by DavesZ#3
I think you mean that the other way around. On the road at high speeds, the high pressure would force more cold air into the CAI. Sitting on the dyno, the only air being forced into the CAI is from the cooling fans in front of your car.
no, actually i meant what i said. when at high speeds, the high pressure zones in the bumper would actually be sucking air out of the intake. i dont know about the Z, but for my G, it is when i am moving at high speeds that air is forced into my Popcharger. we have that scoop thingy between our hoods and grills.
that doesnt make any sense, the molecules in an area of high pressure are naturally going to move to any area of lower pressure, so if the area inside the bumper is of a high pressure than the intake (which it will obviously be since the intake is in vacuum) then more air will be forced in at speed.
