Making the right header decision
Old Mar 29, 2004 | 06:45 AM
3rdpower's Avatar
3rdpower
Default Making the right header decision
I'm considering the DC headers which are ceramic coated (at least it appears). Being that Exhaust with Turbo is extremely hot is this the right way to go given this possible future mod?
Old Mar 29, 2004 | 06:59 AM
EricCartman's Avatar
EricCartman
Default Re: Making the right header decision
The turbo kits come with their own Headers so you wont need this mod if you plan to go with a turbo in the near future..As far as DC headers..Not sure on the quality or performance,but anything is better than the stock manifold..
Old Mar 29, 2004 | 07:36 AM
3rdpower's Avatar
3rdpower
Oh this I didn't realize I better stay away from headers then...
Old Mar 29, 2004 | 08:18 AM
Gsedan35's Avatar
Gsedan35
I tend to agree with that, but remember the borla's are different to and look at the gains they don't do. But I will keep the door cracked for whenever a dyno shows up from someone that has nothing to do with the company or it's resellers. Of course that would mean a dyno posting that follow's standardized proceedures. Posting the scan, done on a dynojet, SAE corrected, 6MT pull done in 5th, A/F ratio's,....you get the idea.
Old Mar 29, 2004 | 09:53 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
your looking at 400+ plus for labor (atleast we charge 400 and we are a dealer)...
ceramic headers will eventually currode... you dont want to go changing your headers because your installed chipped the coating and you have to replace your header the next year from the salty air...
so if you are going to do a header atleast do stainless steel...
Old Mar 29, 2004 | 10:01 PM
Hunter Z's Avatar
Hunter Z
Default Hey Jason
I sent you a PM
Old Mar 29, 2004 | 10:17 PM
Jason@Performance
Performance Nissan
replied
sorry to hear that.. but we will give it a looksie tommorow
Old Mar 29, 2004 | 11:30 PM
DanF's Avatar
DanF
When considering ceramic coatings there are two types to choose from:
CERMACHROME which is a polished aluminum finish, rated to 1300 degrees, more resistant to scrathces, chips and oxidation, but prone to fading if the temp reaches 1300 degrees. (The oxidizing point for aluminum)
Satin ceramics which are typically flat finishes, available in many colors and rated to 2000 degrees, as they do not contain metal flake. They are a thinner coating more prone to scratches and chips but typically will not fade or discolor.
Stainless steel has its place in fabrication, depending on the type of course. 321 is te best and really should be the only choice for headers and exhaust because of its thermal properties and flexibility. 304, which almost every header manufacture uses, is the worst choice for headers because it becomes very brittle when heated. Thus it becomes prone to cracking. But, it is relatively cheap, polishes nice and has been marketed to death by the large corporations.
Though we do not like using 304, demand has proven to out-weigh our stance. No matter how much information we have given to customers, some still prefer to have their products built in 304 stainless.
Just do your resarch and make the best informed choice you can.
Old Mar 30, 2004 | 10:37 AM
TheBigShow's Avatar
TheBigShow
thought i would throw this out there instead of startin another thread: with n/a and n20 in mind, would crawfords b the way to go? thanks.
Old Mar 30, 2004 | 11:45 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
FYI that we ahve sold the DC ceramic coated units for years now with the Honda's and have never had an issue.
Trust me when I tell you you will sell your car before having to replace the header.
But if you are doing turbo, do not buy any headers at all - they will be useless to you regardless of what kit you get as all the kits come with their own (needed to mount the turbos/wastegates)
Adam
sales@czp
Sep 23, 2019 03:30 PM
Tochigi_236
Sep 27, 2015 03:40 PM
